Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
Thread: uSDC problems in my NSX (with pix and video)
  1. #31
    Feb 2005
    Oklahoma
    so would this help my issue as well?
  2. #32
    Apr 2001
    Portland OR
    Quote Originally Posted by 04scooby
    It should. Also, the code I wrote will help with the temperature problem. I'm pretty confident the mod will solve your problem too..
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  3. #33
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    sweet! Just in time for my mobo to fry. Im gonna send this back to ya jeff, i'm not riskin messin somethin else up now that a solution has been found.
  4. #34
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Jeff,
    I had limited success. The 33 ohm resistor seemed to do the trick. Started the truck and the computer fired right up. No more relay clicking! Played around with the computer for about 20 minutes and shut everything off. Tried turning it back on and the computer will not turn on. The led is behaving properly and is on solid with ACC or engine running and blinks once per second with the ignition off. Nothing feels hot enough for a temperature fault and power is coming out of VOUT. Just not getting a power pulse to the motherboard. I'll have to check things out better tomorrow when I have more light and time to check my wiring. At least the clicking is gone now. Thanks!
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
  5. #35
    Apr 2005
    hi i just received one of these friday ordered 2 weeks ago and was disapointed to find that mine sufferes with the clicking noise as well i am not running an inverter i am running a 12 v pc and it still clicks i would have thought as this thread was started a while ago that mine would have had the mod done before shipping as i live in the uk postage is not cheap and takes a while very disapointing
  6. #36
    Jun 2004
    Idaho
    Quote Originally Posted by speedyboy
    The fix wasn't discovered until 4/27, only 3 days ago. The resistor mod seems to be working for me. I did hear it click a couple of times on the first startup the other morning. It was 36F that morning so I don't know if the low temperature cutoff could have been the cause. Hasn't clicked since though.
    Rick S.
  7. #37
    Apr 2005
    Angry oops my bad
    Quote Originally Posted by strohmrs
    sorry didnt look at the dates still my unit is faulty and i need a replacement have tried contacting mp3car shop but have heard nothing have sent them another email tonight hope someone will respond if not then i can only go to paypal for help very disapointed
  8. #38
    Woodbridge, VA
    Blog Entries
    55
    did you do the fix? Jeff said you can send it to him and get the fix done for free. Thats what route i took.
  9. #39
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Glad to hear this has been resolved - so what's the procedure if I bought my uSCD20D from mp3car.com? Do I need to send it to them or to you Jeff to get them repaired/updated? I also hear the clicking, and it "randomly" shuts down the system.
  10. #40
    Apr 2001
    Portland OR
    Quote Originally Posted by Hark
    Yes you need to send it to me and I'll fix it.
    www.mpegbox.com
