Alright....you really should try a little harder to research, there are many places and posts that give all of this information. I know your a noob but that is no excuse.[/lecture]
First of all this page has links to User guide/manual and specs.
The 3 connectors are for a positive, negative, and switched positive. Many people ask about the switched positive. Basically it is a 12v line that turns on with your ignition, just like a remote turn-on for an amp. It is only used for logic-level switching so very little power is consumed from this line.
Oh and the wires that come with the m1-atx (18awg) are, in my opinion, too small I would definatly use 10awg to run the lines to and from the battery.
Its pretty simple, there are no tricks to it just plug n play.![]()
If you have more questions, most likely it has been talked about, so try toharder.
LinkBack URL
About LinkBacks
harder.
