Results 1 to 10 of 17
Thread: Search for a better way....
    Apr 2005
    Minnesota
    I've been reading through the forums like mad for the last week (since i found this site) and searching the net for almost a month, and still am unable to find a good, high power, dc-dc, regulated power supply, anyone want to just kick out some ideas?
    Da_Kooz
    Apr 2005
    Minnesota
    Oh, and I also want it to be simple, that i and others could expound upon themselves, and yes i did notice master's mks
    Da_Kooz
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    use a lower power system
    Signature: [==||========] 20% complete
    Elsewhere
    Build a Sproggy...
    Oh.. You wanted it SIMPLE
    Those are your two options. Build a sproggy or go with a lower-power setup.
    Deal with it or do something to create a better option for yourself and/or the rest of us.
    How about the Wiki?
    Apr 2005
    Minnesota
    That's about what I expected, thanks anyway guyz.
    I'm still working on it, and if I do come up with anything i'll post it
    Da_Kooz
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    What is it you're wanting to power?
    List it here, and we'll tell you what to do.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jan 2005
    well, anything that comes from Mastero generally isn't that great, or well designed...
    I have been working on a switchmode PSU that is basically the same as a mains powered one, but that will run off 10-16 volts...
    so, instead of using underrated switchmode ICs for each rail, there will be a single switchmode controller IC, and a transformer with multiple secondary windings for each rail
    ummm... should be good for 300watts, and fairly small... reliable, and easy to build... only thing is, you have to wind your own transformer..
    Apr 2005
    Minnesota
    >never_stock
    That sounds good, I'd like to see some plans if it works out.
    >confused
    i want to power a some stuff i have laying around, i think it's around 500mhz on an atx board, onboard video-might use a vid card if i want/need svideo or composite out, sound blaster 5.1 card, and a standard dvd drive. that's the base anyway, but i want to get that worked out first and have plenty of power left over for add-ons...
    Da_Kooz
    Mar 2002
    Tucson
    You realize you will be pulling 25 Amps through the primary windings (assuming 100% efficiency). It will have to be a specialized transformer indeed! It can be done, but you'll be dealing with very high switch frequencies, and a very tight transformer design. Not to criticize or anything, but you’re not the first poster to promise the world. If you pull it off you'll be a hero around here .
    Walt
    Apr 2005
    Minnesota
    i have an idea for making a high current voltage regulator out of an old multimeter and some caps....i know it sounds crazy, buy i don't really have anything to lose by trying...
    Da_Kooz
  1. Using advanced search to read the last 'X' posts
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 03-06-2005, 05:38 PM
  2. Search Mode / Jump Mode
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:48 PM
  3. search function
    By IIJasonII in forum FrodoPlayer
    Last Post: 04-30-2004, 12:06 AM
  4. Search function
    By liquid_smoke in forum General MP3Car Discussion
    Last Post: 02-15-2004, 03:43 AM
  5. am the only gettting annoyed with the search logo?
    By kickercivic1 in forum Off Topic
    Last Post: 01-10-2004, 11:37 AM
