Results 1 to 10 of 12
Thread: Newer cars have built-in shutdown controllers?
    Constant Bitrate PaPP's Avatar
    Minneapolis, MN
    So here's my thoughts. . . .
    When I turn off the ignition on my explorer, the windows still work. Why not run the "sensor" lead off my relay powering the carputer/screen to the power supplied to my power windows? Apparently there's still power there, until the doors open.
    Thoughts anyone? This might be a great idea for us "CHEAPOS" out there. Thanx!
    (\__/)
    (='.'=)This is Bunny. Copy and paste bunny into your
    (")_(")signature to help him gain world domination god I can't believe I did it...
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    interesting idea, i like that alot....use a relay for turnon from ignition line....and this for shutting down, sounds cool
    PC Components:
    My work log
    Minneapolis, MN
    You wouldn't even need one off the ignition, as the power to the windows would come on with the ignition anyways, right?
    (\__/)
    FLAC Chairboy's Avatar
    Jan 2004
    I already do that with my 1999 Buick Regal. The radio is actually on the same circuit, so I use the accessory line to toggle my Opus. I turn off the car, even take out the key, and the computer and stereo stay on until 5 minutes pass or until I open a door.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Minneapolis, MN
    awesome! How often do you find yourself waiting to open the door? Do you sometimes give it a hard shut down by opening the door too soon? My shutdown time to hibernate is about 8 seconds on average. That's probably about how long to pickup your crap and change your sunglasses back.
    (\__/)
    Jan 2004
    heh heh, yeah. It's great for listening to the end of songs, etc. It's rare nowadays that I open the door prematurely. If I want to keep the puter on, say, while I'm at a gas station, I just switch the key to accessory. The engine is off, the ignition is unpowered, power is never interrupted to the computer so it stays on.
    http://hallert.net/
    Minneapolis, MN
    wow. I've usually just risked the pump with the car on to aviod that. . . . accessory switch. . . perfect! I'm feeling it come together. . . now where the hell is the lead for my window power, as my radio doesn't stay on. . .
    (\__/)
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I liked that idea for about the first day, then my passenger opened the door and killed the power to the PC as it was hibernating/shutting down/something then ran checkdisk on the next boot up. Not good.
    Jan 2004
    Well, that's different then mine. I use direct power to the battery, then the accessory line signals the opus to shut down. You must be using an inverter setup, Curiousity?
    The Opus is great. I open the door, or the passenger does, and the computer automatically begins the hibernation process. And the Opus provides power until it is done.
    http://hallert.net/
    Mar 2004
    Florence Yall, BFKY
    Oh, I thought you meant ACC would cut the power to everything. That's kinda what I tried but then switched to ACC sensing in the PC, so it's about the same as what you have. The amps are switched by ACC as well, so I get sound until the door opens too and no problems with glitches from starting or switching the key back.
  1. Shutdown Controllers
    By bgoodman in forum Power Supplies
    Last Post: 09-02-2004, 12:10 AM
  2. New Improved ATX Shutdown Unit!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 04-15-2004, 09:52 PM
  3. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 08:30 PM
  4. 2 Jeff Mucha Shutdown controllers
    By dbinnc in forum Classified Archive
    Last Post: 12-20-2003, 11:52 PM
  5. Replies: 18
    Last Post: 02-25-2003, 02:29 PM
