Results 1 to 9 of 9
Thread: Newbie .... Carputer .... problems ?
    Apr 2005
    Question Inverter 600w ....... 220v problem
    Hello to everyone ! im totaly new in the forum , sorry about my english , im from greece
    yesterday buyed a DC/AC inverter 12v --> 220v 600w
    i've connected the 12v power from the battery directly , and i measured the ac currend and always was on 190-205volts , never 220.....
    my car when is off the battery has 12,5v and where on 13,8v
    i've connected my pc , after inverter and worked correctly ...... is possible that the measure (190-205v) was wrong ?
    using the lights , starting engine and some extra power for tft and other stuff , the battery dc volts was going from 10v to 13.8v
    my inverter cuts the power where the dc volts drops down 10.5v .... so my pc is rebooting ......many times my inverter beep and tells me that the dc power is not enough ....
    what i have to do for better working ?
    nevere rebooting .....or hanging my pc system ?
    and regoulating the power......
    thanks
    You can get a bigger battery, larger power wire (this alone may not do it), second battery, or use a tank circuit to keep the PC from rebooting. We have a tank circuit if you cannot build one.
    Don't worry about the inverter's voltage if it works.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    Apr 2005
    thanks for the reply
    i'll search the forum for the tank circuit
    i'm studing electronic engeniering so it would be easy to buildit
    thanks again
    Apr 2005
    What kind of backup battery i need to use , for not having drops in my 12v inverter input ?
    because my inverter stops working when power dropes down 10,7volts
    what kind of diode is needed ?
    any fuses?
    Oct 2004
    That diagram won't work very well as the car starter will suck the backup battery's current as well as the car's battery.
    ColdPhreze
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Apr 2005
    i've put the diode in the wrong place
    this is the correct diagram
    Apr 2005
    I've build the circuit above
    using an mbr3045 diode , but the problem didnt solved..
    where my cars battery falls down to 10.4 , the backup battery dosent
    give the apropriate 12v to the inverter ....
    but the circuit works correctly , if i disconnect the car battery , an using only the backup , and visa versa
    what's the problem?
    Nov 2003
    Marietta, GA
    dtomgr,
    You may want to contact Omeganet/Xenarc (Athens) for some help.
    Good luck!
    MikeH
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Use a sure power inverter to isolate the batteries. It will work like this.
    http://www.surepower.com/isolator.html
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. Newbie Carputer in Zafira GSI
    By madmunky in forum General MP3Car Discussion
    Last Post: 03-31-2008, 04:43 AM
  2. carputer problems - resets and opus wont turn off
    By elserpiente in forum General Hardware Discussion
    Last Post: 03-10-2005, 07:20 PM
  3. The answer to our "Remote Syncronisation" problems?
    By Confused in forum Software & Software Development
    Last Post: 02-17-2004, 09:26 AM
  4. Replies: 4
    Last Post: 02-16-2004, 09:08 AM
  5. Help with parts list for carputer newbie
    By h22lude in forum Newbie
    Last Post: 02-03-2004, 04:07 PM
