Results 1 to 9 of 9
Thread: 5.5V 2.2W Power Supply???
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    5.5V 2.2A Power Supply???
    I have an odd power requirement. I need a 5.5V 2.2A power supply. I've already built a 5v 6A power supply (using a PT6625) and now I guess I need another one.
    The PT6625 will need to remain at the same output (it is driving 2 powered hubs).
    Someone please help. I would assume I can use an LM1084 with some resistors and caps. Please be specific if making a suggestion, I'm not an electrician or an engineer - thanks!
    -HD
    Jun 2004
    Los Angeles
    Quote Originally Posted by joshthepilot
    You can hit up radio shack for their variable voltage regulator. It can do up to 1.5 amps which meets your 2.5Watt specs. It uses 2 resistors to set the voltage. Bring a calc with you because I think it says on the back the simple formula. Then you can buy the resistors at the same time.
    Thanks for the answer...
    Oh Crap - I meant 2.2 Amps...I'm assuming if my device pulled that many amps of this regulator, it would burn out regardless of the size of the heatsink...?
    -HD
    Low Bitrate Mcnovy's Avatar
    Feb 2005
    Denmark
    whats wrong with using the same ic (PT6625) for the 5.5 volt's output..?
    edit:
    i mean, you should be able to use the same regulator (1 for each design )
    just put some resistors to vo(adj) pin 14
    heres is a datasheet
    http://grok.ecn.uiowa.edu/Internal/V...tor_pt6620.pdf
    2 edit:
    28,4k between pin 14 and Ground (pin 7-10)
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    Jun 2004
    Los Angeles
    Josh - thanks for the suggestion. Just to let you know, I'm running (2) 5V 2A usb hubs off the PT6625. I've attached a drawing of what my circuit currently looks like.
    If you have time, please modify it and let me know what I need to do to get me 5.5V on one line while keeping 5V on the other 2 lines. Thanks!
    May 2004
    hd
    you can add a 28.4k ohm resistor between the V adj and the ground.
    it will give you a 5.5 v out.
    Jun 2004
    Los Angeles
    Quote Originally Posted by xtra
    hd
    Thought this would be pretty simple, so I went to Digikey.com and couldn't find any resistor with a value of 28.4k.
    Do these exist???? Thanks!
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you can put resistors in series and parallel to get different values. if you put them in series the values add up... so a 27k and 1.4k in series gives you 28.4k
    Jun 2004
    Los Angeles
    Resurrecting this thread from the dead. Anyone know if the PT6625 can output 10v? If so where do I hook up the resistor? Thanks.
    Jun 2004
    Los Angeles
    NM, started new thread...
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  3. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 05:01 PM
  4. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
