Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: will the opus 150 power my system? I have all the figures
  1. #11
    Apr 2005
    Zip -
    I now know why the engineer at OPUS was not worried about the 12 volt rail. Using the last post as reference, all (or most) of the cpu power is being pulled off the 5 volt rail. This is probably why he wanted to put the POL on the 5volt and not the 12volt rail. it would give the extra 2 amperes required to keep the psu under max amperage load.
    These are my new figures.
    3.3 volt rail
    3.0 AMPS for motherboard/ onboard devices
    1.0 AMP for onboard video (amd says 3.0 AMPS for agp gpx card)
    0.5 AMP for PCI sound card
    4.5 AMPS total for the 3.3 volt rail (Opus 10A max, 13A peak)
    5 volt rail (PROBLEM RAIL)
    6.0 AMPS for CPU
    2.0 AMPS for motherboard/ onboard devices
    2.0 AMPS for 1x DDR dimm 256
    0.8 AMP for IDE hard disk 3.5"
    2.0 AMPS for 4 USB devices
    1.5 AMPS for DVD rom 5.25"
    14.8 AMPS total on the 5 volt rail (Opus 10A max, 13A peak)
    12 volt rail
    0.3 AMP for motherboard/ onboard devices
    0.45 AMP for IDE hard disk 3.5"
    0.3 AMP for cpu fan
    0.6 AMP for case fan
    0.5 AMP mouse and keyboard
    stuff outside case
    1.0 AMP for lilliput touch screen (I want to run it off the OPUS)
    0.3 AMP for relay to turn on amplifiers in car
    4.35 AMPS total on the 12 volt rail without case fan (Opus 5A max, 6.5A peak)
    4.95 AMPS total on the 12 volt rail (if cooling is a problem)
  2. #12
    FLAC -zip-'s Avatar
    Ontario/Canada
    Glad things are working out for you intense. Have not checked Opus website on the POL, but if you need one they will make one for you even if it not released yet. They were going to do that for me.
    Also, dont forget to get them to mod the Opus for removing the ATX (standby) on the 5v line. That way your USB ports will shut off when there is no power.
    I forgot to do that when I ordered mine, now I have to send it back
    Sound Stage
    Eclipse|MTX|Infinity
  3. #13
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you can build the Sproggy 4.5 and modify the PCB a little, it will power the spec well.
    The current sproggy has 10A on 3.3, 10A on 5.0 and 2 X 5A on 12. You can modify it to have more current on 5V and less on 3.3V (5A on 3.3 and 15A on 5V). That is how I power my Matrix PC.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #14
    Apr 2005
    i have updated my first post for anyone who would like the information.
  1. Opus cycles power every 5 secs....
    By xtentialyst in forum Power Supplies
    Last Post: 05-31-2006, 01:20 AM
  2. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 02:39 PM
  3. OPUS 150 low battery shut down
    By archimense in forum Power Supplies
    Last Post: 09-08-2004, 03:28 PM
  4. New system design...power issues...
    By lookinco in forum Power Supplies
    Last Post: 08-10-2004, 03:11 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 06:32 PM
