Results 1 to 6 of 6
Thread: Choices to power m10000 or m12000
    Apr 2005
    To power the m10000 or m12000 board with the usual array of accessories.
    whats the better setup here? pro's and con's wise
    Casetronic C4-CT-DC150L $45 + CarNetix P1900 ~$130?
    or
    OPUS 150 $179
    also is there a downside to wiring a xenarc directly to the cig lighter power as apposed to running off of the psu? will I need a fuse or anything?
    Thanx All!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    mkay.... lets try searching the forum before posting questions that are easily answered.
    i would say stick with the opus. It is a great power supply and will survive a crank. Also i don't think you need anymore than the 90w. I have a m10000 and a lilliput with all sorts of extras and it runs fine off the 90w
    Of course you will need a fuse if its not a regulated power supply.
    Run your screen off the psu i don't have any problems
    Apr 2005
    my mistake, I'm horrible with searching. I'd rather run the screen off of the vehicles power so I wont need a long cable run to the trunk. So you say I do need a fuse if I run off of the cig wire? what fuse do you recomend?
    the opus is regulated right?
    Nov 2003
    Marietta, GA
    supernoob,
    First let me say, there is NOTHING wrong with your asking a question like this. It has NOT been answered (to my knowlege) before in any forum. I wish people would help instead of criticize, especially with a username like "supernoob".(/rant)
    Secondly, I would disagree with anitmatter. Why spend an addtional $50+ for an Opus when the P1900 + Casetronic C4-CT-DC150L will provide equivalent functionality (survive engine crank, startup/shutdown controller, DLYON trigger) plus additional functionality the Opus does not have (Pulse Start, seperate =12v/+13V output for screen), especially if you buy a case with the C4-CT-DC150L already installed (Travla C137-120, C138-120, C158-120, or Morex P4-3677/88/99). This is a very reasonable solution (and question).
    ...sorry to rant, but I am believe there are more people using the "search" comment than there are newbies ansking obvious questions.
    MikeH
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    Well said Mike :-)
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    Newbie loudhoward's Avatar
    Nov 2004
    Quote Originally Posted by supernoob
    or
    OPUS 150 $179
    Thanx All!
    Hi, I run an MII 12000, Lilliput, PCMCIA wireless ( with extended 5db gain ariel, ) CDROM and external Belkin 5v USB2 HUB, GPS USB mouse all running on an M1-ATX ( 90w) PSU. Cant beat it, cost me 52.00 delivered. I am sure you can get them in the US or from http://linitx.com/product_info.php?c...roducts_id=598
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Casetronic C137 120watt power supply
    By Change in forum Power Supplies
    Last Post: 11-13-2005, 09:15 PM
  3. Switching from Car to House power?
    By Deadnick in forum General Hardware Discussion
    Last Post: 01-11-2005, 09:09 PM
  4. Power Consumption For P4 MB?
    By almera in forum Newbie
    Last Post: 11-27-2004, 01:47 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
