Results 1 to 9 of 9
Thread: how many outputs to turn on a pentium 4
    May 2004
    Question how many outputs to turn on a pentium 4
    i just build my own power supply using the TI ISR chips.
    I already wired all the 12 v, 5v, 3.3v , ground, and 5v to the power good pin.
    what else do i need? i can't turn on my pentium 4.
    does the -12 and -5 and pw-on pin need to be connect to somthing?
    please help !!
    Nov 2004
    Cali
    Quote Originally Posted by xtra
    please help !!
    P4 does not need -5V, however it does need -12V. And what are the power ratings for your psu?
    I have found you an argument; I am not obliged to find you an understanding.
    Jan 2005
    http://hardwarebook.net/connector/power/atxpower.html
    what exactly are you trying to do?
    do you have a mains powersupply that you are trying to reduce the number of wires from, or do you have a DC-DC powersupply that outputs those voltages?
    Nov 2004
    Cali
    Quote Originally Posted by never_stock
    what if its the 24 pin connector? that one doesn't have -5V
    May 2004
    Quote Originally Posted by rushnrockt
    12v x 4.5 a
    5v x 13 a
    3.3v x 10a
    is this good enough for a P4 1.4GHz?
    anyone has idea about the PW-OK and PW-ON pin? I wired the pw-ok to a 5v voltage source and pw-on is open.
    are you sure I need -12 to turn on the computer? according to what i read, it's only needed for Serial communication.
    May 2004
    thanks for the link. I already have them wired up according to the diagram except the -12 and -5 v. and i m not sure about the pw-on and pw-ok pin.
    I have my own dc-dc power supply.
    Nov 2004
    Cali
    12v x 4.5 a
    5v x 13 a
    3.3v x 10a
    i am not so sure about the 12V line... you might be needing more juice, i recommend you look online for the power consumption. Also, is the motherboard the same as in the link XTRA gave you, or does it have more pins? The newer ATX standard does not have -5V and has slightly different pinout.
    May 2004
    my mobo has the 20 pin connector. I just found out the -12v and -5v is not needed for the computer to boot up. I cut the -12v and -5v in my AC PSU, the computer still boots up with no problem .
    Jan 2005
    serial ports might not work...
  1. Replies: 9
    Last Post: 02-24-2005, 03:53 PM
  2. Navigator Turn by Turn V2
    By CRCinAU in forum GPS
    Last Post: 08-08-2004, 06:49 PM
  3. Replies: 4
    Last Post: 03-25-2004, 06:53 AM
  4. Auto turn on for the DWW TM-710VGT?
    By -al- in forum LCD/Display
    Last Post: 12-02-2003, 04:50 PM
  5. Replies: 0
    Last Post: 07-23-2002, 12:45 AM
