I am planning on using a "powerstation" http://www.maplin.co.uk/Module.aspx?...ldID=&doy=18m4 like that.
But my mobo hasnt arrived yet, i will let you know, but seeing as it can give 17ah
im sure it will work.
Where can I get an adapter so I can plug my M1-ATX into a wall in my house so I can power the cpu inside and set everything up.
Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
just go to radio shack and get a 12v adapter and conect it up.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
yeah but dont just buy any 12volt adapter, you need to make sure it can supply the amperage that the M1 needs which I would think would be around 5 to 10 amps
肚子笑痛了
S60 Install
would this work?
link
modified of course.
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
how do you want to modify it?
it is 80W and the M1 is 90W so will draw 90W + inefficiencies at full load (eg 90% eff. => 100W).
I would personally use an old ATX PSU that has a nice strong +12 DC line of 10A (120W). You could get away with less if you then connected some of your 5V drives/devices to the AC PSU to lower the M1 load. But keep the mobo running off the M1 for testing etc.
I use the 12v line off an old 150w AT power supply i have. works great.
System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
Progress: Installation: 90% Dash fabrication: 80%
Parts Needed: USB GPS
are you guys just suggesting using an ATX power supply in the house and m1 atx for car.
or snip off the 12v from the atx connector on an ATX p/s and connect it to the leads on the m1 atx.
i showed that link because that's what i've been using to power my tc10000 in the house and was wondering if i could use it for my m1 atx?
thanks.
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
Why not use a 12v battery of a car and just keep charging it up?
Originally Posted by meyer64
EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
or just use a 12v car battery charger or is that very dangerous?
