Results 1 to 4 of 4
Thread: would this blow my fuse quickly?
    Jun 2004
    i will have 2 amps in my system, totaling 100amps draw. if i used a 100amp fuse to power the amps, plus the opus and my dsp unit (3amp), would that blow right away? problem is, there is no 125amp or similar ANL fuse- if it would cause a problem, i'd have to run a 2nd 12v line to the trunk just for the carputer/dsp.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    probably not......i've got an amp that was supposadly pulling 65 amps, had it fused with a 50 and had my opus on there there too....worked fine
    PC Components:
    My work log
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Mar 2002
    Tucson
    100 Amps at 12 Volts = 1.2 KW of power. I doubt that you'll ever really pull that much juice, even on the loudest of bass booms. The voice coil in your speakers are not wound with #4 cable. I think most car audio amps are spec'd based on what they theoretically can deliver, and not on actual load testing. Just my opinion.
    Walt
  1. Fuse question
    By Peoples in forum General Hardware Discussion
    Last Post: 03-14-2005, 10:52 PM
  2. Xenarc fuse and power help required
    By Scouse Monkey in forum LCD/Display
    Last Post: 02-18-2005, 03:45 PM
  3. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
  4. Power Supply Connections
    By nick9871 in forum Power Supplies
    Last Post: 07-12-2004, 07:25 PM
  5. Wiring from battery and switch questions
    By bombboyer in forum Power Supplies
    Last Post: 02-06-2004, 07:17 AM
