Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: To the experts
    Low Bitrate Speg's Avatar
    Mar 2004
    To the experts
    I've read 2 different views and I still am not 100% this will work.
    I am building a desktop in the car with 80 gig hard drive, burner, P3 800, 512 ram, couple fans...etc.
    I'm looking at This for the power and a ITPS for it as well.
    So will these 2 components work fine for my set-up?
    Please experts, help a brudder out
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    this isn't really an expert question ... but no matter.
    post the specs of your proposed system.
    200W is plenty of power ... buuuuuut ...
    In short I'm going to guess that this isn't the best solution for you. I'm not familiar with the PW-200... but if it's like the other PW series supplies, it doesn't condition the 12v line. In a desktop PC with a desktop hard drive, this is a bad thing.
    The ITPS will condition the 12v line ... but it does a pretty crappy job of it. Because of the linear regulator it uses, you need to feed it abour 13.5v in to get 12 out ... which means it's only good to you when the car is running.
    The ITPS is really only usable when you have all laptop components ... even then it's not ideal.
    You'll be much happier with an OPUS or even the Carnetix 1280 with a PW series Ps (which is what I use ... just upgraded from ITPS)
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Mar 2004
    Well, all last summer I used my desktop plugged into a inverter. Every now and then if the car was ideling for a while, the inverter would beep saying "NEED MORE POWER", so a few shots of gas, it was best kind.
    So this summer, I will have the following:
    P3 800
    Asus Mobo
    Sound BLaster Live
    cdrw-dvd rom
    512 ram
    80 gig Maxtor 7200 spin
    on board video
    all in a plexi glass custom case.
    So maybe I should just plug it in like I always did and get a ITPS so I don't have to power up/down every time.
    Opinon?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    ITPS is crap.
    Requires 13.3V in to give 12V out, and it only provides 60W of regulated power.
    Get an Opus 150W. Power supply is the heart of your system, and something you really should get right...and it's cheapest if you get it right the first time round.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Mar 2004
    But they arn't cheap
    LOL
    Aug 2003
    Essex, England
    Quote Originally Posted by Speg
    LOL
    From my experience it's cheapest to get the Opus straight away.
    I've had an inverter + desktop PSU, a Morex + ITPS, and THEN i got an Opus.
    I wish I'd found this forum sooner and had someone tell me about the Opus before I'd bought the other things, then I would have saved lots of money.
    Garry
    www.aimee.cc
    Mar 2004
    Well, do you know for one used or cheaper?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you may be able to squeeze it all onto an M1-ATX as you are using onboard video but the 3.5" HDD would concern me and is the DVD drive a laptop one?
    Mar 2004
    Well, I'm making the case myself. The cd-rom was going to me a normal one, but I can get a laptop one. Would that reduce the power usage?
    Mar 2004
    Bristol
    yup it would. It will also run off 5V. Do some power calcs for each voltage channel and see what you need.
  1. Audio signal experts - please help (two line-level inputs wired in parallel)
    By pkarmouche in forum General Hardware Discussion
    Last Post: 04-12-2005, 09:43 AM
  2. OBD-II Experts
    By pirate_king00 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-17-2005, 08:03 AM
  3. Some questions for Experts (Mercedes Install)
    By Longkesh in forum LCD/Display
    Last Post: 08-23-2004, 09:25 AM
  4. Calling all audio experts
    By marcos_guy in forum General Hardware Discussion
    Last Post: 11-10-2002, 10:23 PM
  5. Brake system problems - any experts?
    By kaysee in forum General MP3Car Discussion
    Last Post: 05-06-2002, 05:45 AM
