Results 1 to 7 of 7
Thread: M1-ATX power shutdown failure
    Mar 2005
    NYC
    Does or has anyone had a problem shutting down their system where it would restart again after? While using the M1-ATX?
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Are you issuing a shutdown command before you switch off the ignition?
    Apr 2005
    Exclamation M1-ATX misbehavior
    Quote Originally Posted by DK888
    Yes, in some situations I cant use shutdown because it will restart the system.
    When I suspend/hibernate, the 12v rail becomes 5v and the 5v drops to 0v.
    This issue almost damaged my lilliput!
    If 5v is supplied for a long time it will destroy my display.
    I've heard about an updated firmware. Maybe it solves the problem, but it did not arrive yet.
    Do you know if your M1 is going to 5v in the 12v rail too?
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    just purchased M1, it worked few times then gave me the shutdown problem, 5v on the 12v, I really hope it can be fixed
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Do you have the latest firmware?
    Nov 2004
    Italy
    well I purchased it a week ago, I hope to have it
    is there a way to verify? if it is not the latest I have to find out a pic programmer somewhere..
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Nov 2004
    Italy
    I took a pic from a working M1 and put to mine, the problem remain so it is not a firmware-related problem
    mini-box.com says to ask a RMA
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  1. why do i have to push the power button after shutdown?
    By kalito in forum General Hardware Discussion
    Last Post: 03-15-2005, 10:00 PM
  2. Opus 90w Shutdown Power off Porblems
    By antimatter in forum Power Supplies
    Last Post: 04-15-2004, 12:24 PM
  3. ATX, ITX DC-DC Power Supply
    By Navigator_82 in forum Power Supplies
    Last Post: 03-14-2004, 11:26 AM
  4. BIOS option for EPIA that reboots after power failure?
    By rordog in forum Power Supplies
    Last Post: 12-16-2002, 09:46 AM
  5. Do I really need ATX power???
    By Griffin_Dodd in forum Power Supplies
    Last Post: 01-31-2002, 04:39 PM
