Search on terms "power calculator". You'll find links to power calculators that will allow you to figure out if the Opus is enough.
Hey,
Im planning and buying carputer parts to put in my cavy but im having some problems deciding what to use for power. By the way I alreadyand
but my brain is getting fried.
here is what im planning:
foxconn 650m02 mobo w/ onboard video,audio,lan
celeron 2.4GHZ 400fsb
lilly 7" touchscreen
external DVD/CD-ROM drive (powered by usb)
USB GPS
60gig HDD
512MB pc2100 RAM
Card reader (maybe)
I was looking at using the OPUS 150W dc-dc but I dont know if it has the power that I need. Any sugestions?
Want to:
check out my thread, i just went through the exact same thing.
http://www.mp3car.com/vbulletin/show...050#post450050
If you look beside the CPU and just above the SIS 650GX chipset there is a 4 pin power connector that I spoke about in other threads. This means that your CPU gets most of its power from your 12 volt rail. On the opus there is a max of 5 amps. 12x5 = 60 watts max. The 2.4 gig celeron alone pulls close to 50 - 60watts at peak. So no I don't think its gonna work with that mobo and cpu.
ok I have been looking around and some people have 2.4 celeron systems that are running off the OPUS 150W but from what I have been reading the 2.4 celeron sucks 59.8W which fills up the 12V rail. I have a DVD drive and a hard drive that come off the 5V rail but I think im gonna be screwed to find the rest of my parts that dont pull from the 12V rail. Does anyone have a suggestion on a PSU setup?
your hard drive and dvd rom pull from the 12 volt rail as well.
that system will pull 8 amps or more on the 12 volt rail easy.
you could try a less powerful cpu. if not, run a power inverter.
I thought Opus came in 80watt, 120watt, and 150watt configurations?
Want to:
