Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Power calculator with rails breakdown
  1. #11
    Apr 2005
    hmmm, I think the values are dated. I just tested a micro ATX board with 7200rpm 120gb hdd, 16x dual layer dvd writter, 10/100 ethernet, 2200+ sempron, 640mb ddr, integrated video and sound, 2 fans. While under test I had the dvd rw burning a dvd. The 12volt current reading was 7.75 - 8.12amps. The reading dropped to 6.48 amps when the dvd finished the burn. Now factor in the fact I was using a 12 to 120vac inverter and a standard ATX ps. The combined losses of the 2 probably amounted to .5amp or more. Bottom line.... I'd estimate the true power consumption at 12.6v x 8.12a = 102.3w minus the power converstion losses of 6.3watts, yeilds 96watts. The calculator estimated in excess of 140 watts.
  2. #12
    May 2005
    Here's an Epia calculator Maxxell
    http://resources.mini-box.com/online...simulator.html
    A pic is worth a thousand words.
  3. #13
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by Vee24
    Not so sure if the PSU recommendations on this link are any good. We know M1-ATX limits combined watts in 5v and 12 v rails to 50. I Ran up the watts to more than 50 watts for 5 volt and 12 rails combined and it still recommended M1-ATX....
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  4. #14
    May 2005
    Ok, PSU recommendations are no good, but do you think the power consumption for devices are close?
  5. #15
    Dec 2004
    Bay Area, CA
    It looks like it.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 12:08 AM
  3. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 02:39 PM
  4. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
  5. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 07:14 PM
