Results 1 to 10 of 15
Thread: Power calculator with rails breakdown
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Exclamation Power calculator with rails breakdown
    Check what I found!
    P.S: Just got myself Dremel 395 kit from eBay
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    wow. that is really useful! this should be made a sticky. I know i've seen my share of "how much power does this take?" threads. Thank you
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    HAHAHAHAHA I have NINE AGP VIDEO CARDS!!!!! and NINE floppy drives!!!! It's 1300 watts!!!!!!!!!!!!!!
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Nov 2004
    Cali
    Quote Originally Posted by lastberserker
    Check what I found!
    7 watt agp card? right
    I have found you an argument; I am not obliged to find you an understanding.
    Apr 2005
    Seattle
    Quote Originally Posted by rushnrockt
    It wasn't updated for 2 years. And, yeah, there are 7W AGP cards
    Dec 2004
    Miami, FL
    Too bad it doesn't have the Epia chipset. Also, anyone know how much to add if you're running a lilliput (or two) off the power supply?
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
    Mar 2005
    lilliputs take up 9 watts or at least mine does
    Apr 2005
    Some of those values are not right.
    my western digital 80 gig 7200 rpm drive takes .45 amps from the 12 volt not 2.2 amps like the calc suggests. I would recommend looking at your hard drive and cd roms ... the values are printed right on the top for you.
    Also I have an AMD duron 750. It pulls most of its power from the 5 volt rail not the 12 volt again like the calculator says.
    Nov 2004
    Cali
    Quote Originally Posted by intense
    Most of the new processors pull their power off of the 12V rail, so they are right in that respect. However the 7W AGP card... even though they do exist, they do so in garbage, newer AGP's take anywhere from 15 to 70 Watt.
    Apr 2005
    If your motherboard has an additional 4 pin square shaped power connector (This is separate from the regular 20 pin motherboard power connector). Your motherboard will give the cpu its power from the 12 volt rail. If you do not have the additional 4 pin connector on your motherboard then your cpu will get its power from the 5 volt rail.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
