Results 1 to 10 of 14
Thread: Laptop automatic startup using a single shot relay
    Mar 2004
    Belgium
    I've been looking for an automated way to startup my laptop upon ignition.
    I didn't like the idea of having to push a button manually.
    Therefore I thought of this solution which is a combination between wake on link (modem) and a single shot relay (http://controlsupply.com/a4121.htm).
    Would it be possible if I would wire the ignition simply to my DC-DC laptop converter, and let the s-s relay 'sense' current on the same wire and pulse the single 'wake on link' signal to the modem?
    Apr 2005
    I have been looking for a way to do this as well, however i dont think a "wake on" option would be the best idea, seems complex, what about maybe just simply having some kind of circuit that would jump the switch on the laptop directly?
    Im not sure how to solve this with out modification.
    Jesse
    Quote Originally Posted by jonee
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    its a pulse relay. It will dot he job you want yeah. they you set the PC to standy or hibernate after so many minutes after AC is turned off.
    There is quite along thread about ti somewhere...
    Remote laptop startup
    there is a circuit to build your own pulse relay there witha couple of components and some otehr stuff.
    Mar 2004
    Belgium
    Jesse, As for the startup: I can't use the "pulse relay" to pulse the power button because, when the ignition is on and the laptop is working, it is possible that the ignition is switched off for a few secs/minutes and then restarted (eg after filling up at the gas station).
    At that time the laptop will probably still be running, so when the car 'ignites' it will send a pulse to the power button, meaning to send the laptop to standby/hibernate.
    I don't think that if the laptop is on and it receives a wake on ring/modem, that anything will happen, and that's what is supposed to happen.
    Scouse, thanks for the link.
    Low Bitrate McFreak's Avatar
    Mar 2005
    McKinney, TX
    What about telling windows to do nothing when the power button is pressed. That way the pulse will work when the laptop is hibernating, but if windows is running it shouldn't do anything if you stop for a short time. (Depending on what you have the hibernation time set when running on battery)
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by McFreak
    wow, that is much better than what i did. i ended up using a 5v relay hooked up to a usb port to only allow 12v into the pulse relay if the computer was not powered on. i was concerned about the 5v relay burning up because of the 12v running through it... i like your way much better. time to make a change.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Mar 2004
    Belgium
    Well, that would work once windows is up and running, but have you tried pushing the power button before windows is loaded? Eg 5 seconds after booting. My laptop shuts down immediately in that case.
    But maybe there might be a solution if we could 'tell' the pulse relay that after a pulse, it shouldn't pulse again for let's say 20 secs.
    Anyone know of such a pulse relay?
    Oct 2008
    I would like to do something similar, but with my xbox. I could use the single shot relay to "Push the button" but i would like it to "push the button" again when the remote power is lost. Im not worried about it turning off the xbox when i turn the car off and back on or whatever. pretty much what i want is...
    car turns on --> relay switches because of remote wire --> xbox turns on
    car turns off --> remote power lost relay pushes switch --> xbox turns off
    can anyone help, this is all i need to finish my project.
    Nov 2006
    Rubidoux, CA
    I am just now implementing a system for starting up my laptop using a small 555 timer circuit. I'll post up the schematic in a little bit. Basically, I have it monitor the 5V on one of the USB ports (which is only on when the PC is running), and if it is NOT on, it pulses a relay, wired to the power button. It worked on the bench, just gotta give it a shot in the real deal.
    Nov 2006
    Rubidoux, CA
    Here's the schematic of what I'm working on. Basically, the 555 timer is continually cycling. (about 3 seconds on, 1 second off). When it is on, it turns on Q1, which pulls down the voltage after R4, turning off the relay. When it is off, and if Q2 is also off, the voltage will raise, causing the relay to pick up, and press the power button on the laptop. Once the computer is on, the USB5V will keep Q2 turned on, so it will not energize the relay anymore.
    This was a quick and dirty solution, using parts I had. I've seen others using microcontrollers and such, but this seems to work just fine for me. I was going to use a Phototransistor or Otpoisolator off the power on led, but the USB 5V seems a much more reliable method.
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Remotely startup laptop...? (wake on lan)??
    By Pro in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-13-2006, 07:57 AM
  3. Broken Laptop Startup
    By fabiolover2002 in forum Newbie
    Last Post: 11-05-2004, 04:51 PM
  4. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  5. Laptop Startup
    By prophet in forum Power Supplies
    Last Post: 07-10-2004, 01:53 PM
