Results 1 to 4 of 4
Thread: Need help understanding efficiency and voltage regulation
    Mar 2005
    kansas
    Question Need help understanding efficiency and voltage regulation
    The power supply i am looking at is the keypower 250 watt. Im just confused on a few things about what the efficiency actually means. And what to do to compensate it. And if i need to worry about voltage regulation.
    input: 9 Vdc-18 Vdc 37 A
    DC output Characteristics
    Output
    Voltage V1
    +5V V2
    +3.3V V3
    +12V V4
    -5V V5
    -12V V6
    +5V SB
    Max. Load 25A 14A 10A 1A 2A 1A
    min. Load 3A 0A 1A 0A 0A 0A
    Peak 30A 21A 12A 3A 2A
    Total combined output of +3.3V and +5V shall not exceed 125W
    Cross
    reg.% ±5% ±5% ±5% ±2% ±10% ±5%
    Cross
    Line Reg.% ±1% ±1% ±1% ±1% ±1% ±1%
    Ripple & Noise
    50mVp-p 33mVp-p 100mVp-p 50mVp-p 100mVp-p 50mVp-p
    Efficiency: 60% at typical load
    Hold up time: 16ms at full load
    Power good signal: 100~500ms
    Shout Circuit Protection: A short circuit on any DC output will cause the power to latch.
    Over power protection: Peak power protected to between 110% to 125% of continuous rated power.
    Over voltage protection: +5V:5.5-6.5V
    Teamperture range:
    32°F ~122 °F ( 0~ 50°C)
    Relative Humidity: Operating: 10~90% rh
    Storage: 5%~90% rh
    Safety Standards: Meets UL 1950, CSA 22.2 No.234, TUV IEC 950, FCC Class B, VDE Class B
    M.T.B.F.: 100k hours at 25°C
    Dimention: (W x H x D )
    150 x 86 x 142 mm/ 5 7/8"x3 3/8"x5 1/2"
    My question is about the 60% efficiency. Does this mean that the power supply will actually be pulling 400 watts to make its max 250? And is the efficiency related to the voltage regulation at all? Will this PSU be susseptible to power spikes? Or do all 12 volt dc to dc PSUs have strict voltage regulation? I have searched on this and ive read so much i went cross eyed and confused myself. I know i need a power controller. Thats a give with this. Just dont know if i will need a seperate voltage regulator or not and what type of problems will i be looking at with only 60% efficiency? THis is basically my last dumb newbie question. Thanks for the help.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    as for the efficiency, yes, you are correct. efficiency is power out divided by power in. so at 250W out, you will need 416W coming in. that also means you're dissipating the difference in the converter... 167 watts of heat.
    and no, efficiency is not related to voltage regulation.
    a DC-DC should be relatively tolerant of voltage spikes. there are large inductors and capacitors in it, not to mention active voltage control by the circuitry... all of those things act against power spikes.
    as long as you operate it within specs, it should have no problems with output voltage, and you should not need a separate voltage regulator. after all, that is the job of a DC-DC... providing a constant output voltage with various input voltages.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by evandude
    SNIP
    SNIP
    That is a lot of heat... Be well ventelated and use a fan
    TruckinMP3
    Read the FAQ!
    Mar 2005
    kansas
    well my setup will be installed in a custom center console. Well in the armrest of it actually. It will be setup pretty much the same as a desktop with the PSUs exhaust fan open to the cab and another 120mm fan doing the same for the rest of the PC.
    Will this suffice for cooling?
    and thanks for clarifying my concerns. Man after so much reading and getting different view points this **** can get a little confusing,
