The 12V rails doesn't mean to be combine together. If you do, it will die soon.Originally Posted by Juliemac
Use one of the 12V for HD/DVD ROM. The other 12V use for the mobo and P4 Aux connector.
I built the system and it tested fine. But when I tried on the target system which is a Shuttle 1.8 with 512 mb/ 40GB hd it would not pass POST.
There are 2 main 12v lines to the mother board. One on the main connector and one 4 pins Aux 12v.
Separate these lines to the (2) 12v regulators. Separate it starts fine. Together the current draw appears to much.
Now for the final build!
Julie
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Together they would not start the PC. It would not even get past post. When I split them it booted and ran well. Even the temp was lower.
As for the short life, would that be the MB or the power supply?
Very cool! Can you answer my question now?Originally Posted by Juliemac
By the way, what do you mean by "split"? Use separately? Then it's the same thing MatrixPC suggests.
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
To answer your question, it's the PSU and also could cause your system as well.Originally Posted by Juliemac
When you combine the 2 together, you are running 2 regulator in parallel. In this case, one regulator will output more power than the other (2 same components are not always have equal quality), and will overload and burn.
The 5V rail is also running in parallel, but in this part, the 10uH inductor is used to connect the 2(3) together and reduce the change that one is pushing more than the others. It's not a perfect design, but works cuz one of my Sproggy (Supra) is running over a year without any problem.
Some EE guys can answer more to about running 2 regulator in parallel and this design in particular. I am not EE by trade, but with a little interest in electronic to play around with.
The output of the LM1084-12 is 5 amps. There lies the problem. It seems the system needs more current than can be supplied. National says the outputs can be tied together.
Any one tried this? Mastero?
Julie
hey I was thinking of building a MK-4.5 but before I got and buy a kit do you guys know if it has the 4 pin connector and can support a:
celeron 2.4 (~60W)
foxconn mobo with onboard video,sound
laptop external dvd-rom (usb powered)
laptop HDD (pulls from 5V rail)
512 RAM (2 sticks pc2100)
I know that the celly will pull 5A from the 12V rail its self
thanks
Ok. Got it fixed. The core voltage of a Duron on a Shuttle MB maxes out at 5.4A with 3.4A nominal, so the single 3.3v regulator is enough.
The 12v section takes greater than 5A to start the system properly so the following fix will work!
1) Remove both 10uh coils from the 3.3v regulator section and jumper it first reg to the output pad.
2) rebuild the serial coils from 12v+ to the 12v+ with the center points flying. Add a 1000uf cap to the center point to ground. Attach the yellow 12v line from the ATX and the other 2 lines from the P4 supplimentary lies to this point.
This allows the Celeron/Duron/Sempron on a Shuttle computer to start successfully every time. Temps are reduced as well.
A bit more sheet metal work, in car wiring and dash work and the system will be ready!
Thanks all for all your help.
Can you sketch of what you did?Originally Posted by Juliemac
It may help other people better than just text description.
If you wanna join the two 12v line isolate them with two diodes say any diode with more than 5amps capacity should do. the trick is to have the two line joined after the diode so they dont kill each other.
12v Diode
}---------12v 10 amps
12v Diode
Enjoy
Mastero
