i've seen this before on other sites, 250watt dc-dc psu
dont know anyone who actually uses it. Its a bit pricey. And whatever happened to the 300 watt they were supposed to come out with.
Does anyone have any experience with this make of psu ? http://www.cartft.com/catalog/il/407
This one hasnt gone on sale yet but Looks like its the right money for what you get 250W continuously (apparently).Just doesnt say if its got the start up and shut down options of the opus
.Heres what they do say
Dimensions 150mm[W] × 140mm[L] × 86mm[H] Standard ATX PS/2 size
Weight 2.0 kgs
Input Voltage Range 9 - 18VDC
Output Power maximum 250W (continuious)
Remote sensing +5V and +3.3V
Over Power Protection Load over 130%±10% of max. output power : shutdown
Over Voltage Protection +5V, +12V & +3.3V Auto-recovery
Short Circuit Protection Main outputs shutdown and latch off
Over Temperature Protection OTP Level is set at 110°C
Operating Temperature -20°C ~ +70°C
Storage Temperature -40°C~+80°C
Cooling Build-in One 80x80x25mm Ball Bearing Fan with max. air flow 42CFM
The extra power over the opus is the temptation(extra hard drive and two more monitors)and i also run full size drives .I also have a power problem with my touch screen
when i plug in my xbox controllers (think the rumble uses to much power) basically doesnt work when there in .So i would also use it to power the hub that the gps,touchscreen,keyboard and xbox controllers are all pluged in to
what do the expertsthink ?
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
PC Components:
My work log
Could be a tempting solution for my Insight P4 system that. I paid £100 for a 90W OPUS and this one is only £116 (to UK) for a 250W - hmmm.
Why do you need a shutdown controller. Can the Mobo's power switch not just be connected to a ignition switched live?!?
I bet it doesn't shut its self off though if battery supply voltage drops, ie it will flatten the battery if used with engine off. Mind you my opus 90 used to flatten the car battery before it shut down if I used it too often with engine off.
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
It looks like the Keypower 250W
And the site says "£135.20 with 16%VAT"
This is just like a normal ATX PSU only it is 12V not 230V Nice 3 year warranty though.
The problem is that there is no shutdown/startup controller. You can easily set the Bios to boot upon power restore but you would have to make a way to get the PC to autoshutdown and then kill the power to the PSU ore the 5vsb will rape your battery in a few days and the constant higher than normal standby load (wrt normal car systems) will kill it eventually.
You could rig a basic shutdown controller using a dumy UPS setting and a or alternativel use Girder to do a shurdown/hibernate on a from a button press or form an infra red signal when you lock the car etc etc but if the PC hangs etc then it will stay on. yOu would need some sort of timer system to eventually just kill the PSU. You would also need to set the input on a relay controlled by the normal way you start the PC (eg ACC live or door loacks) and by itself so when the PC shuts down the PSU kills its own power. But you need to isolate the relay feed sor use 2 to stop you connecting car 12V into your PSU output.
Or you can jsut buy a proper shutdown controller which might be a better option!
thanks for info
what (proper shutdown controller ) do you recomend ?
If that was aimed at me I pass it over.....not looked into any in detail. mp3car store has one.Originally Posted by skydiver
[QUOTE=Scouse Monkey]It looks like the Keypower 250W
Not when you remove the 16% vat which UK'ers dont pay its about £116 like I said![]()
That's the Keypower, just like Andy said!
[QUOTE=Tuned Vitesse]No you will jsut pay 17.5% when you import itOriginally Posted by Scouse Monkey
