Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 72
Thread: why are atx power supplies so cheap?
  1. #21
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    WTF is the Tualatin? I had never heard of these chips... oh well...
    and in what way would this setup be better than say a shuttle or other mobo, with a P4 or celeron (or even a ITX P4 board), with a slimline DVDRW drive, and a large laptop HD (or 2) should be able to power it with an opus I'd think... or a keypower...
    And also, why do you want that much stuff in the car? Like the kickass graphics, is your display going to match that graphic card quality?
  2. #22
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    If it's obnociously huge enough! come on! haven't you seen pimp my ride?
    (wow that shows gay)
  3. #23
    São Paulo, Brazil
    Does the screen come with neons in the back like that ghey PSu? hehehe
  4. #24
    Apr 2005
    put the specs of the computer into this calculator and see how much power it uses. way over 150w thats for sure:
    http://www.jscustompcs.com/power_sup....php?cmd=INTEL
    the computer is listed on that calculator.
  5. #25
    São Paulo, Brazil
    Quote Originally Posted by zoomzoommazda6
    put the specs of the computer into this calculator and see how much power it uses. way over 150 thats for sure
    What computer are you talking about? if it is the configuration that I mentioned, then I'm sorry but I have a similar one running..... dont believe me come and see...
  6. #26
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    those power calculators imo are full of *****. they kept reading anywhere from 210 to 250 watts for my system, yet the OEM psu its running quite happily on is rated for 160W max.
    Your everyday carpc geek and tech guru at your service. *bow*
  7. #27
    São Paulo, Brazil
    That power calculator is somewhat inflated IMO.... my personaly setup came to over 200watts on that... + it doesnt take into consideration the separate rails....
  8. #28
    Apr 2005
    put the specs of the tualatin into the calculator (link above) and see how much power it uses.
    dont forget to add the
    GeForce FX 5700
    the two sticks of ram and so on
    it has two hard drives but when using the calculator leave out one
    I get 155watts with just the CPU, video card, and hard drive
  9. #29
    Apr 2005
    it calculates peak wattage thats why it seems inflated.
  10. #30
    São Paulo, Brazil
    1) why are you stuck on that setup? Have you considered that you wont need gigabit ethernet, motherboard might be inneficient? what will you use your ubber-graphics card for in the car?
    I'm not against high-end machines in the car like some users are, but just when it becomes an issue of "so much power I absolutely need a huga-*** inverter and water cooling system" I think you can review the machine choice maybe...
    2) do check other calculators, and the ratings for the components themselves!!! This calculator is much inflated like I said (and vchat confirmed)...
    3) check out a calculator with separate rails if you can (there is a link in one of the recent threads) as you might be surprised that all your 200 watts are on 12v, and then even the PSU you are thinking about wont work... (I'm just giving an example)
    PS: as far as I can remember all calculators I've seen calculate peak (or almost there) wattage... but the 150w rating or 90w rating or whatever isnt always peak... so you need to match these...
  1. Opus power supplies ---> for AMD mobile???
    By folagana in forum Power Supplies
    Last Post: 09-08-2004, 07:39 PM
  2. Mp3Car.com Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 10:39 AM
  3. A very cheap way to power your PC
    By clint_jasper in forum Power Supplies
    Last Post: 01-08-2004, 10:40 PM
  4. dc-dc 250 watt power supplies
    By dscustoms in forum Classified Archive
    Last Post: 05-30-2002, 01:05 AM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 07:47 PM
