Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 72
Thread: why are atx power supplies so cheap?
  1. #61
    Nov 2004
    Cali
    Quote Originally Posted by 0l33l
    Umm... the MP is a SERVER CHIP!
    God damn! I hate false information
    Hey, with two 400gig monsters, he might need the server/workstation chip just to index them.
    I have found you an argument; I am not obliged to find you an understanding.
  2. #62
    Newbie Wyattx17's Avatar
    Apr 2005
    California
    Mybad, I meant XP-M. It's either that mobile CPU, or i'm going all out and i'll just get a 939pin mobo and 64bit. I have almost a terabyte worth of mp3s and Divx Xvid. So 800Gigs would be just right for me.
  3. #63
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by rushnrockt
    The MP is just like the XP except it has a bridge connected. Same thing with the XP and the XP-M. Connecting a bridge can give you powernow technology, and connecting another bridge can give you multi-processor capability.
    Quote Originally Posted by Wyattx17
    Mybad, I meant XP-M. I have almost a terabyte worth of mp3s and Divx Xvid. So 800Gigs is perfect for me
    Ok... good.
  4. #64
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    Take an inch or two off the exhaust pipe and it will be a gay jew
    - just read this thred
    Don't be a pussy, install your processor
    crunch - oops
    I'll just cut the chrome outer trim off - that looks like foreskin!
    Basically you dont want to force anything in place, and you want to get stuff in the right direction
    sex??
    wow I love the Forums here
    I will add some useless info "see below"
    Adding a huge video card eats a lots of power
    see I told you it was useless
    And that hot pink PS did look a little gay
  5. #65
    Apr 2005
    OPUS Solutions 150W DC-DC smart power supply, PATENT PENDING, is designed specifically for ATX motherboards to be used in an automotive environment.
    will the opus work with the pundit-r? what mobo does the pundit-r have?
  6. #66
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by zoomzoommazda6
    I think you'll have to send it to opus to change the timing on or something. to confirm that.
  7. #67
    Raw Wave RoyN's Avatar
    So Paulo, Brazil
    I was told by Opus that they shouldnt need to change anything, but that some pundits dont have an ACPI power switch header, and for that you must solder the power switch to the mobo, or make a small extension header for that...
    no biggie...
  8. #68
    Apr 2005
    Quote Originally Posted by RoyN
    no biggie...
    no biggie for you maybe but I dont know **** about power and such.
  9. #69
    So Paulo, Brazil
    Can you join 2 wires togther? That is basically what will need to be done... splice the power wires and join them to the opus... you'll probably want to leave in a connector to be able to change between the opus/stock button, or even leave both connected. You also need to make sure you dont have the wires inverted, but that is just a question of trying it and reversing the wires if it doesnt work... I dont know what you mean about power or anything.... just join the two tips of wire........... or my personal suggestion GET HELP FROM SOMEONE....
    I have been trying to help you along, but your attitued throughout has just spelt "I shouldnt be the one doing this"...
    Maybe you should consider purchasing a ready-made system and have it fully professionally installed.
  10. #70
    Raw Wave tj!2k4's Avatar
    Oct 2004
    I'm going to have to report this post for excessive use of the smiley
  1. Opus power supplies ---> for AMD mobile???
    By folagana in forum Power Supplies
    Last Post: 09-08-2004, 08:39 PM
  2. Mp3Car.com Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 11:39 AM
  3. A very cheap way to power your PC
    By clint_jasper in forum Power Supplies
    Last Post: 01-08-2004, 11:40 PM
  4. dc-dc 250 watt power supplies
    By dscustoms in forum Classified Archive
    Last Post: 05-30-2002, 02:05 AM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 08:47 PM
