Results 1 to 5 of 5
Thread: M1-ATX - Offdelay doesn't work
    Feb 2005
    I have a M1-ATX with the latest firmware.
    With the jumper set to 5sec/45sec, and turning the ignition to off, my PC does not turn off after 5 sec (offdelay doesn't work?)...
    However, it does turn off after 45 sec (with hardoff, I believe)
    What is wrong, is there something I have forgotten to setup, or is my M1-ATX broken?
    Thanks in advance
    /Jisc
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    If you have the power button wired to the ACPI header, and you push it, does the machine turn off? If not, then you need to check your BIOS and your OS settings for how power button events are treated.
    Feb 2005
    Quote Originally Posted by Change
    When I do as you say, I need to hold down the powerbutton for 4 seconds, then it powers off.
    In Bios power settings, there is a setting for "power off by power button", but changing it does not affect anything...
    Aug 2004
    California
    Check the settings in Windows too. The M1-ATX sends a single pulse to the ACPI header, it doesn't do the 4-second "hold". You need the PC to shut down on a single press of the button.
    In XP, Control Panel->Power Options->Advanced and make sure "When I press the power button on my computer" is set to shut down.
    By the way, I think I've posted this at least three times now, and I've seen others post it too. The feature of this site REALLY DOES HELP. I strongly suggest making use of it.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    how you guys upgrade M1 firmware? I just purchased it
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  1. will pcchips 748 mobo work as a car pc?
    By hud in forum General Hardware Discussion
    Last Post: 03-10-2004, 09:55 PM
  2. Will an ITPS work with an ATX motherboard
    By NightHunter in forum Power Supplies
    Last Post: 02-24-2004, 03:33 PM
  3. Does your Opus's low voltage shut down function work?
    By cproaudio in forum Power Supplies
    Last Post: 12-19-2003, 08:24 AM
  4. Opus ATX and ITX PSU - Difference?
    By phoTToniq in forum Power Supplies
    Last Post: 09-22-2003, 04:21 AM
  5. DVD and CD burner dont work above win 98
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-09-2002, 08:56 PM
