Results 1 to 5 of 5
Thread: any need for isolated power supply?
    Nov 2004
    Cali
    So as usual at 2 in the morning I come up with a weird question. Hopefully this time I will get something out of it
    After staring at the carputer power supplies, I am having trouble figuring out if they are isolated or non-isolated. So my question is whether there is any need for a dc-dc converter in a car to have isolation. Thanks for the input.
    I have found you an argument; I am not obliged to find you an understanding.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    like for audio reasons?.. dc-dc is great in that respect because you never can get a 60hz buzz .
    just make sureyou have goot grounding all over..
    or am I missing it?
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    FLAC evandude's Avatar
    Mar 2005
    Maine
    there's no real reason to use an isolated converter. For AC power supplies, it can make sense, because it's safer to not be connected to AC directly. But in a car you WANT all your electronics to be grounded together for various reasons, and it's not like the input voltage of the car electrical system is any more dangerous than the output... if it's just for reducing electrical noise, then there are better methods you can use... mainly designing a GOOD non-isolated DC-DC, and/or adding smoothing caps and inductors in strategic places in your electrical supply as needed.
    Nov 2004
    Cali
    Quote Originally Posted by neon_eddy
    or am I missing it?
    evandude got the right idea. I was just wondering if there would be any advantage of say an isolated flyback versus buck/boost converter.
    Low Bitrate Juliemac's Avatar
    Upstate NY
    Buck/boost typically operates at 100khz. You would need to reach the 10th sub-harmonic of this frequeny to hit 10Khz (your hearing range). At this level the noise problem will be minor. Good filtering on the supply lines will do the job for you.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  3. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  4. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 05:01 PM
  5. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
