Results 1 to 10 of 13
Thread: itps faq
    Mar 2005
    Sportsvan
    itps faq
    hi,
    is it possible to bypass the regulator on the itps, and then use my 250w powersupply on the itps?
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    yup..
    search google for "itps pdf" .. and you should get a pdf of the manual for it..
    there are 2 pads under the regulator that you short out.. (the part with the heat sink)
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    Mar 2005
    Sportsvan
    can it handle the "real" 250 w, its not the cheap one... i'm thinking about heating and stuff
    Nov 2004
    Coon Rapids, MN
    well.. you can use a relay..
    have the ITPS turn on a relay and have your 250W psu connected to your battery via your relay ..
    the ITPS may work.. as it won't be regulated.. but I'm not sure because it does turn it on and off.. so the relay may work best
    Shawn
    Mar 2005
    Sportsvan
    i know, but i'm seeking someoe who have tried this, cause i can hear, and feel, that it's draining my battery, when the car stands still for a couple of days
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think what you're asking is whether you can simply use the ITPS as a startup/shutdown controller and bypass that with your 250watt inverter.
    I certainly wouldn't run the 250 watts "through" your ITPS. It would probably overheat it if your system drew more than 60 watts, even if the regulator is bypassed as the board and tracings are sized for 60 watts.
    It would be much better to go with a relay, as suggested. The ITPS would energize the relay and the power would pass through the relay, not the ITPS. I believe you could also use that same signal to the motherboard to tell it to start as well.
    Search on terms "ITPS startup controller" or some variation of that to find posts about people who have done this.
    Want to:
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    i thought that said "itps fag"
    CarPC install is starting to come along again...
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I did to seriously.. hahah guess we both need our eyes checked
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Mar 2005
    Sportsvan
    LOl
    Mar 2005
    Sportsvan
    Should i give it a try?
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  3. ITPS Startup Shutdown Controller Not Working
    By EBJUSTIN in forum Power Supplies
    Last Post: 09-11-2004, 09:04 PM
  4. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  5. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
