That looks like circuits I've seen that will do startup/shutdown for you. I'll leave it to the electrical genius' to answer but I think that's it.
Ok, first of all, im quite n00b on electrics so i need sum help please![]()
In attached picture relay passes a pulse of 12v true relay right ?
My question is can this diagram be used to press pc´s power button to
turn it on ? Or how to modify it to use for it ?
Want to:
Yup thats a momentary relay connection indeed, i just dont know how to modify it the way that it connects 2 wires, not actually give out pulse of 12v ...Originally Posted by Bugbyte
You only need a short pulse to signal the PC to turn on. How long does that circuit stay "pressed"?
Want to:
Terminals 87 & 30 should go straight to the motherboard pin headers for the power switch. They only need to be shorted together briefly. That 12V fused would probably kill your motherboard. The on time of the relay will depend upon the value of the RC network (resistor & cap).
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
This layout, ˝second which is good for this purposeOriginally Posted by Bugbyte
Ok this was the information i wanted to knowOriginally Posted by strohmrs
Thnx
Now i just need to figure out how do i prevent it to press again if i take a leak or sumthing and shutdown engine for a while and then start it again.
-Kungmpton
Depends. Does your current power supply survive cranking the car? If not, don't bother. If so, put a switch to break the signal line when you stop (that is, normally closed but you would set it to open). That would prevent the signal from being sent to the mobo.
Want to:
Yeah i have tank battery stuff, no probs with cranking. How do you mean, put a switch ? A Manual switch ?Originally Posted by Bugbyte
I was thinking like i need sum sort of time based switch.
Switch stays active after turning of car for ˝h and prevents relay system to send pulse to mobo. If line goes active inside ˝h interval, it stops counting. IE mobo stays on for ˝h after turning of car.
Now you're starting to get to the point where you might be better to just get a shutdown controller.
Rick S.
