Results 1 to 10 of 13
Thread: my power setup
    Apr 2005
    my power setup
    regardless if im building a mac or pc, i think this is still a ower question
    im not very worried about startup and shutdown problems.
    my 'puter is a mac, and i have o problems letting it boot whie im driving
    i am using this 200 watt psu http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.300/.f
    will this inverter work? or one like it?
    http://www.compusa.com/products/prod...108&pfp=SEARCH
    im new t inverters, does it have to be wired directly to the battery, or can i go from a 12v cigarette lighter type pluyg, i see in the picture it has that kind of plus so i was just wondering. since my comp will be located in the trunk it would be easier to use a cigarette lighter plug.
    will this setup work?
    eric
    Fusion Brain Creator
    Mar 2005
    that inverter will work
    you can go cig lighter or direct ot battery, but if you go direct to battery, it will likely survive crank, which is good
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Wire it to the battery. Running it through the cigarette lighter is like smoking while filling your tank. Mostly, something won't happen. But it might.
    The cigarette lighter will heat up, melt and possibly catch fire if you pull too much power through it. Also, the wires to the socket really ought to be beefier.
    You won't be able to power a Mac Mini through the DC PSU. The inverter will work, however I've heard the the Coleman inverters are good quality and will survive cranking.
    Want to:
    Apr 2005
    if i dont realy care abot surviving crank, can i just start the car then start the computer?
    also, is it hard to wire to the battery?
    thanks
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No. Two wires. One +, one -. Keep them straight
    Want to:
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You'll need to put a switch in line if the inverter doesn't have one. If you leave the inverter on for several days, it could drain your batter.
    Want to:
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You'll need to put a switch in line if the inverter doesn't have one. If you leave the inverter on for several days, it could drain your battery.
    Want to:
    Mar 2005
    Quote Originally Posted by Bugbyte
    the fuse should protect the cig lighter, but it's easy, you don't even have to run a negative through teh firewall.
    Apr 2005
    so, definatly wire it to the battery? i fust dont know hoe im going to get te wires into the trunk.
    cigarette lighter definatly wornt do the trick?
    damn
    well ok whatever
    thanks eric
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Quote Originally Posted by peacefrog226
    damn
    well ok whatever
    thanks eric
    No it wont. Just run the wire under the car along the frame rails. Then drill a hole in the trunk and use a grommet to feed the wire through. Its not that difficult. Then just ground it to anything metal. Its easy. Do not forget to fuse it. Put the fuse as close to the battery as possible.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  2. Power setup scenario - Suggestions?
    By Coeus in forum Power Supplies
    Last Post: 01-16-2005, 04:30 PM
  3. Switching from Car to House power?
    By Deadnick in forum General Hardware Discussion
    Last Post: 01-11-2005, 09:09 PM
  4. temporary carpc, will this power setup work?
    By bobthebaker in forum Power Supplies
    Last Post: 10-11-2004, 04:21 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
