The contacts are the? the power wires for the amp? yea you can use that.Originally Posted by TRONiC
I would go with just the M1-ATX why would you need a carnetix with that? the M1 regulates and starts-up-shuts-down.
i will not have my amplifier in my car when i get my car pc. can i connect the powersupply using the amplifier contacts in my car? i will be using the C134 Travla case. and a DWW-700M TFT.
Sholud i go for a M1-ATX instead of the Built-in 60W DC power board. or have both the M1-ATX and CarNetix CNX-P1260 12V DC-DC regulator?
And can i wire it using the car amplifier contacts?
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
why are you removing the amp? you will need it to power the speakers!
This:
if i could connect the car computer to this and get the power from the car.
I will use an external audidy 2 or something. For audio.
If im wrong then someone please correct me, but the output from any sound card on a pc will be too low for passive speakers. You will still need an amp to increase the output.
As i said, someone please correct me if im wrong!
You are dead rightOriginally Posted by rickster
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
cheers stevie, I thought I was on the right lines
Tronic, you need something to amplify the output from the sound card, external or not. The output on a sound card is made to match headphones or very small computer speakers....ones that take a lot less power than the ones in your car. So, basically, you have two options:
a) use an amplifier
b) run it through your head unit (if it supports auxiliary in)
Da_Kooz
