what is your alternator rated at?
17A wire doesn't mean it's thick enough to avoid a large voltage drop over a long piece of wire. What gauge wire is it? What is the voltage at the computer?
hasnt got a voltage drop out. 12.64volts are being delivered to the front of the car.
not sure about alternator, thats not an issue at the moment.
So that 12.64 V is under load? I.e. with the computer connected and drawing it's 13 A?Originally Posted by Jaz
well the computer doesnt seem to be working properly unfrotunatly. lol
but yes the time it did successfully boot it had that voltage.
13amps is the peak power tho, it shouldnt be pulling that all the time... hardly at all i expect. maybe at spin up, but cant see it getting to 13amps.
i dont think my setup can be any more than 150watts under load
what is the voltage when you turn on the CarPc..?
if the voltage drops, maybe you should try putting a Cap close to the Pc..!
the best way to messaure the voltage would be with a osciloscop, og a analog multimeter..!
Sorry for the english
CarPC Specs.
Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
Jaz - try connecting to the known voltage again - the one where it did work. See if the PSU fried or something
OK, grab a multimeter and stick it into the yellow / black wires on a HDD molex connector. If it's analog, the polarity matters, if it's digital it won't.
See what the voltage is THERE. My guess is 9 or 10 volts, Ideally it should be around 11.8 to 12.3.
Now measure the INPUT to the PSU of the PC at the computer. If it's low, get a thicker + wire.
I'm guessing you used too high gauge wire and there's a lot of voltage drop on it.
done a few measurements now.
At the car psu when its off, there is 12.2volts
when its on its at about 11.6 (i guess this is the problem)
when i go to back of car and measure the battery, it also is 11.6 when computers on.
And when computers off its 12.2 volts.
i guess the battery isnt up to the job.
cant work out why it worked well for so long in the house tho.
Maybe you need to charge that battery??
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
