Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Car Wattage Problem
    Jaz
    Jaz is offline
    Apr 2005
    Car Wattage Problem
    Hi all
    finally got my car pc working properly with the powersource out of the car,
    ive now moved it into the car.
    the power source in the back, and the car pc in the front.
    Now what is happening is the pc is acting like its not getting enough wattage. hard drive wont spin proplery and motherboard doesnt power up until the 2nd request. but then still wont get into xp because of the hard drive.
    however this was working fine on the same power source, out of the car.
    Now will this be the problem? i am running only the positive wire up the whole legth of the car... The ground for the power source is grounded in the boot, and the ground on the computers psu is grounded at the front of the car.
    Will this effect the amount of wattage it can pull? if not im stuck.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Need more info,
    what power supply, what motherboard, what size wire did you run
    肚子笑痛了
    S60 Install
    FLAC evandude's Avatar
    Mar 2005
    Maine
    First off, WHAT is your power supply?
    in my experience, the hard drive won't spin up properly when the input voltage is too low. Sounds like you are dropping a lot of voltage between your "power source" and your computer, over the long wire... why don't you put the power supply up back?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If it's an ITPS, it won't work properly when the car is off. Even if it's not, try starting the car, then starting the PC.
    Want to:
    Jaz
    Jaz is offline
    Apr 2005
    other details are irrentlivent. i just wanted to know if having different grounds points would effect wattage.
    wasnt the problem, something else had changed... i was using the cigerette lighter on the jump station instead of the clamps. seems the ampage on the cigerette lighter is regulated where as on the clamps its not...
    basically i have got a 2nd battery (a jump station), running a 200watt PW-200 whatever power supply.
    In my house, hooked up to the battery it works fine and did for over an hour with no problems on multiple occassions.
    Now i have got it in the car, same setup as in the house, and it doesnt work fine.
    it worked for about 7minutes then stopped working correctly.
    back to the drawing board i guess...
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    what guage wire are you running as your power?
    are you sure you have a good ground point?
    test at where the 12v in/out is with a multimeter and check what your voltage is.
    Jaz
    Jaz is offline
    Apr 2005
    voltage was right. 12.64volts or something similar.
    grounding points, one is using same as head unit, other is using a main car grounding point, which brake lights etc use.
    Power cables are rated up to 17amps.
    i was under the impression though that cables rated lower will still supply the current, but will be unsafe and may melt etc.
    i have a feeling a 13amp cable may be used at one point.
    but 13.5amps is the peak for the car psu anyway.
    might just try and run a ground direct from battery to pc and try that
    Newbie Auri's Avatar
    Jan 2005
    Indianapolis, Indiana (USA)
    Running from the battery is so much more convenient than using an inverter. If you have an ITPS you can just set your computer to hibernate when you kill the ignition and then it will come right back to where it left off. Of course, that all assumes you have reliable power going to your machine... look into a direct battery connection - you'll never go back
    BTW, I discuss all that in my book Geek My Ride, available from Amazon now. I've set up a web site if you have any questions (www.geekmyride.net).
    Good luck!
    -Auri
    Low Bitrate Mcnovy's Avatar
    Feb 2005
    Denmark
    use as short ground cables as possible.!
    use youre chassis etc.!
    test the voltage on the computer, and not on youre psu.!
    you wire have som voltage drops, så the most accurate wuold be to test the voltage on the yellow cable on the harddrive.!
    use minimum as thick ground cable, as youre "hot" cable.!
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    Jaz
    Jaz is offline
    Apr 2005
    im not using a invertor, im using technically a battery (which is also a jump station)
    I am using the chassis as a ground, and i have short cables at the moment.
  1. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 10:25 PM
  2. Those of you that have used Peal N Seal...
    By Defiler in forum General MP3Car Discussion
    Last Post: 09-22-2004, 09:45 AM
  3. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
  4. Invertor problem - plz help!
    By hasato in forum Power Supplies
    Last Post: 08-27-2002, 12:07 AM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
