Results 1 to 4 of 4
Thread: xbox power supply
    Apr 2005
    xbox power supply
    I want to put my xbox in my car without using an inverter.
    From what Iíve found by searching, this is what I need:
    ATX DC-DC PSU-What kind do I need (links to some options would be good)?
    Power converter-this thing
    Will this set-up work?
    Will the power supply be able to power the DVD and hard drive of the xbox as well as an lcd screen?
    Does the power supply connect directly to the battery?
    I have no clue about this stuff so any help would be greatly appreciated
    Elsewhere
    Quote Originally Posted by jvanm3
    Yes.
    I'd think an Opus 150 would be able to handle all of that. I think it's been tested by someone here, even. Search the forum.
    Yes.
    How about the Wiki?
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    It should, the xbox uses 100 watts, so then you have 50 watts to spare assuming you get an opus 150.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    So you can get an Opus 120
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  3. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  4. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 05:01 PM
  5. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
