Results 1 to 5 of 5
Thread: Powering my PC
    May 2005
    Powering my PC
    I have a normal desktop PC. I want to put it in my car and power it through and iverter...i will also be powering a 15 inch lcd screen. I was wondering how powerful my inverter should be for this?
    Could someone please advise me?
    Deep
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    ( PSU Wattage + LCD Wattage ) * 2 At Least!
    May 2005
    Looking for an inverter for example it says 300W and 1000W peak.....should all my electronics equipment add up to less than the true power or peak power? If you get what i mean? haha
    thanks
    Aug 2003
    Greece
    Theoreticaly an 300W/1000W inverter works if you use a 300W consuming hardware. When you switch your hardware on, it can consume peek wattage which in your case is 1000W. Theoreticaly.
    As a rule, you should use at lease double what you theoreticaly need. So I f you r PSU+LCD consumes lets say 350W, it would be a good Idea to use an 600W+ inverter. Inverters are NEVER what they are advertised to be!
    Apr 2005
    Minnesota
    Your equipments power draw should add up to less that the true or RMS power...otherwise you risk barbecuing your inverter...while it's in your car...fun stuff.
    Da_Kooz
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. External PC Card adapter for Verizon BroadbandAccess
    By Bluebisz in forum Wireless Communications
    Last Post: 02-24-2005, 10:11 AM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
  5. Powering the pc off and on
    By Holden__V8 in forum Power Supplies
    Last Post: 02-27-2002, 12:52 AM
