sorry for the cross-post, but i tried this in the newb section and didn't get a lot of answers, so i'll try here since its power related stuff.
First, what i bought: WTS: Carputer + Xenarc 700TSV
Now my Q's:
1. It is a morex 3677 case that came with what i believe is the morex 60w car power board. it is obviiously not wired for power since it came with the opus 90w unit hardwired to the carputer instead. So, can i remove the morex board and replace it with the opus board so its not mounted to the ouside of the case like it is now?
2. in the first pic, the power SW "plug" was not connected to anything. should it be, and if so, on which 2 pins. they are not maked accordingly on the MB. There is also a "plug" with a green wire and a white wire was not plugged in on the MB as well. the other end was plugged in on the Opus 90w power board to the "PWR-SW" pins. again, where would it go on the MB?
EDIT: In regards to the green/white wiring question, i just found the Opus wiriing diagram for the 120w unit replacing the 90w one. i assume its still the same. anyone know for sure?
3. the last picture is of a 2.5mm plug that is wired into the main power harness to 2 black, 1 yellow, 1 red wires, that i don't know what it would goto power. it doesn't fit the Xenarc screen, so... any ideas?
4. lastly (for now), i did not get a power cord for the xenarc screen. is there a way to power it off the carputer like with the CNX-P1260 PSU thats under the xenarc accerssories section? or do i need something different for the xenac/opus power combo?
thanks a lot!
