Page 4 of 27 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 261
Thread: small size 150W(7-18v) with shut down controller
  1. #31
    Small size 150W ATX power supply with ITPS
    Features
    1. Both indoor use and carpc use which can be switched
    2. Full 150w output even when at +7V input
    3. Capable for P4 main board
    4. +7V to +18V input and wrong wired protection
    5. Car battery over drain protection
    6. Auto start and shut down procedure for carpc usages
    7. Extra ability on preventing the harmful carpc LOCK/RESTART problem while you starting the engine which was reported on almost ALL other power supplies
    8. High efficiency of 92%
    9. Really the smallest size of 130x66x48
    10. Temperature controlled cooling Fan in order to lower noise
    11. All side mounting design for mount anywhere
    12. Lower price and three month produce return service policy
    Inbox:
    1. 150W DC-DC power supply
    2. 3 wires input cable
    3. 20 wires ATX output cable
    4. 5 plugs accessory output cable
    5. 2 wires power button or main board control cable
    6. Instruction Manuel
    Wiring your power supply:
    1. Connect the 3 wires input cable to your car battery or indoor power adapter DIRECTLY with RED to the positive of the battery or adapter, BLACK to the negative.
    2. Connect the YELLOW of the 3 wires input cable to the car lock and ignition control (ACC) DIRECTLY. If your use the power supple with in door adapter, connect this YELLOW to the positive output or left it open with no connection.
    3. Connect the main board control cable between main board power swith pin and B port if you are using this power supply with your carpc system and be sure to switch the mode switch to mode CAR position. Jump to step 5.
    4. Connect your case power button to port A with the 2 wires power button cable if you are using this power supply with you indoor desktop device.
    7. Connect the 20 wires ATX output cable between this power supply and your main board.
    8. Connect the 5 plugs accessory output cable with your other device egg. Hard disk, soft disk drive, CDROM. If you are using an old model of P4 main board, be sure to plug in the additional +12V plug to the main board.
    9. Switch on your car if you use carpc or press the case power button if you use a desktop system to turn on your device.
    Carpc ON/OFF procedure:
    to be continued....
  2. #32
    Feb 2005
    Hi..
    Any updates on this??
    Malaysia
    -Alfa Romeo Giulietta 1982 with 1992 Alfa 75 2.0 Twin Spark Engine-
  3. #33
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    crap! i just bought a opus
  4. #34
    FLAC evandude's Avatar
    Mar 2005
    Maine
    The ITPS is a specific product made by iTuner... (presumably it stands for "iTuner Power Sequencer") http://www.mini-itx.de/iTuner/itps01.jpg
    Perhaps you mean it contains a SDC (shutdown controller), because it obviously doesn't contain an ITPS.
    On a sidenote, from an elecrical engineer's standpoint, I like how all the small parts are mounted on small vertical PCB's, that's a pretty cool idea for saving space, especially when there's already tall components on the board so the vertical boards aren't obtrusive...
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  5. #35
    Nov 2004
    any more details on indoor use?
  6. #36
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by dragonBTV
    Battery protection? YES
    reprogrammable? NO
    Is it as stupid as the ITPS? YES almost the same as OPUS150
    I am writing the Instraction, please somebody correct my poor English.
    So you can't adjust the timings?
    No problem with the engish
    Features
    Inbox:
    to be continued....
    I think that featrures #2 & #4 can be combined into one.: 2. Full 150w output from +7V to +18V input with reverse protection.
    should read:
    9. Small size of 130x66x48 (UNITS! cm? in? meters?)
  7. #37
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    9. pretty sure they are mm.... pretty standard in most countries too... xcept the US I guess... But yes, I'd put it in units, and also add the measurement in inches (1inch = 2.54cm)
  8. #38
    Dec 2004
    Where its windy
    Looks like an exciting product! Do you think it would power the following?
    Asus Micro ATX motherboard
    AMD Athlon 1800 XP
    1 Stick 256mb DDR memory
    PCI wireless
    20gb laptop hard drive
    combination cdrw/DVD Rom
    2 80mm system fans
    video and sound are both onboard.
  9. #39
    Dec 2004
    BE
    def interested. When is this coming out?
  10. #40
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by 0l33l
    It have to be in mm. You know how big it is in cm? That is bigger than 3f x 2f x 1f. I wouldn't consider it a small size
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Unbelievably cheap, small size motherboard!!
    By gsand in forum General Hardware Discussion
    Last Post: 10-09-2003, 12:47 AM
  2. small proggy to shut down my lcd?
    By etrik in forum Software & Software Development
    Last Post: 12-30-2002, 12:16 AM
  3. small size Video card
    By jtk in forum General Hardware Discussion
    Last Post: 11-24-2002, 10:21 PM
  4. Shut down controller
    By danl in forum Power Supplies
    Last Post: 10-16-2002, 02:29 AM
  5. small size computer besides shuttle?
    By Ces///M3 in forum General Hardware Discussion
    Last Post: 05-13-2002, 03:11 AM
