Results 1 to 10 of 11
Thread: Alternative ways to power up pc from cold
    Apr 2005
    Is there any other ways to power up pc than power button ?
    i got hp e-pc s10 that wont power up from power button at all, power button is dead. Broken sumwhere from the mobo :/ Is there any other ways to power up this computer ?
    I Know computer works, its just the damn power button thats broken :/
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    do you still have the power button cable connected to the mobo. If so its easy as touching those two wires together for a second. A USDC or similiar would do the job of starting and stopping ur computer for you.
    Apr 2005
    Quote Originally Posted by Sonicxtacy02
    Like i said, power button system is brokwen from the mobo. Those 2 pins are useless ... :/ I need alternative way, any ports or anything to start up ?
    Elsewhere
    Quote Originally Posted by kungmpton
    Most newer motherboards have a wake-on-LAN or wake-on-ring feature in the BIOS. However, you've got to turn the thing on to be able to get into the BIOS to change those settings....
    Is there any of the pin(s) left that could be shorted momentarily to trigger a power on?
    How about the Wiki?
    Apr 2005
    Quote Originally Posted by DarquePervert
    Nope, i dont think there is. All the pins on the row are used to leds etc.
    How does wake on lan work ? Howto trigger it ?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    How do you know the computer works if you can't get it to turn on?
    Want to:
    Apr 2005
    Quote Originally Posted by Bugbyte
    After it went broke, i managed to power it up once with "power loss", ie i pushed power cord in and it started up...
    After i shutted it down next, i realized that it was power button system that was broken ... :/
    Mar 2002
    Tucson
    From my experience, you should be able to short the green wire on your ATX power connector (I'm making an assumtion there) to ground (the black wire next to the green), and the power supply will come on as soon as the switch on the back is turned on. I use a small piece of solid copper wire, but a paper clip will also do. At least that's how all of the ATX supplies I've dealt with work.
    Hope that helps,
    Walt
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    I'm having trouble understanding what you mean by "power button system is brokwen from the mobo". Does this mean that the pins on the mobo snapped off, the switch is broken, or the pins don't do anything when closed?
    If the pins snapped off, try jamming something into them - like a paperclip or a needle.
    If you the pins (or parts of them) are still there, and you can bridge them with a wire or something, what happens? If nothing happens, try removing the CMOS batt for 20 seconds (or use the Clear CMOS jumper), replace the batt/jumper, and try the pins again.
    IMHO - if something happened to shear the pins off, chances are the force did something else to the motherboard, too.... You might be out of luck...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Elsewhere
    How about the Wiki?
  1. 150w PC 300w Power inverter... help?? Please..
    By MINI-Cooper-S in forum Power Supplies
    Last Post: 03-16-2005, 07:25 AM
  2. Here's an alternative power source....
    By A Boy and his Miata in forum General Hardware Discussion
    Last Post: 11-21-2000, 12:44 PM
  3. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 11:39 AM
  4. Have to switch inverter off and on to power up pc
    By mbowler in forum General Hardware Discussion
    Last Post: 08-22-2000, 12:00 AM
  5. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
