Results 1 to 2 of 2
Thread: M1-ATX Case Incompatability???
    Jan 2005
    M1 doesn't seem to fit in a Morex 3688 Case without removing the USB wiring/PCB from the front of the case? I'd like to keep my front USB ports. Any ideas???
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    No need to remove anything but without major surgery you can keep only one front USB port operational.
    1- Remove the connector.
    2- Carefully bend the pins up enough to clear the capacitors.
    3- Plug the bottom row of the connector to the upper row of the pins.
    That is what I did.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Remove my pc guts and put into smaller case
    By muldrick in forum General Hardware Discussion
    Last Post: 09-03-2006, 09:12 PM
  3. does the opus 150 mount in a normal atx case?
    By mattress in forum Power Supplies
    Last Post: 04-18-2005, 10:09 PM
  4. Case pulled to bits
    By Ascension in forum Hardware Development
    Last Post: 04-07-2005, 09:07 AM
  5. i´m on search for the smallest case for micro atx
    By b7turbo in forum General Hardware Discussion
    Last Post: 07-04-2004, 03:52 PM
