Results 1 to 8 of 8
Thread: Opus 150 question , help...
    Jun 2004
    AZ
    I just got a replacement Opus 150 and all hooked up correctly. I can not seem to get it to power up my M10000 mobo when I start the car. I checked all voltages coming in, 12 V ground, remote 12 V....all checks out. However, My mobo will power on if I hook up a power button to it and manually turn it on once the key is turned in the iginition. The Opus is brand new. Thoughts?
    May 2005
    check acc?
    Jun 2004
    AZ
    yep, acc works fine. I thought this would be the problem but it shows 0 vs with no key turned......12 V key on.....any other ideas?
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Broke OPUS?
    Quick! To the Popemobile!
    Feb 2004
    North Aurora, IL
    is the green/white wire that sends the signal to the mobo to tun on hooked up properly, check the polarity on it.
    Jun 2004
    AZ
    polarity good
    Feb 2004
    North Aurora, IL
    what are your leds doing on the board, when you plug everything in?
    compare your led flash codes with the ones given in the manual to help trouble shoot the problem.
    otherwise, i guess contact opus.
    Jun 2004
    AZ
    all checks out, I just emailed MP3car.com for an RMA. I dont think it is right, especially since I had one beofre and know how it works.
  1. Need Help have searched OPUS 150 wont start
    By cl6four3 in forum Power Supplies
    Last Post: 05-07-2005, 01:48 PM
  2. Opus 150 and Athlon XP?
    By philstuf in forum Power Supplies
    Last Post: 04-18-2005, 09:05 AM
  3. OPUS 150 watt now in stock in the official mp3car store!
    By Zip-Lock in forum Power Supplies
    Last Post: 06-24-2004, 07:56 AM
  4. Fs Opus 150 Power Supply
    By vp911 in forum Classified Archive
    Last Post: 06-07-2004, 06:05 PM
  5. OPUS 150 three flashes
    By spyda in forum Power Supplies
    Last Post: 03-22-2004, 09:27 AM
