Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: M1-ATX microcontroller source
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Source code for the M1-ATX's microcontroller is now available from http://www.epiacenter.com/modules.ph...rticle&sid=529
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Woohoo! I've been waiting for them to do this. Finally we can start talking about custom mods.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    can someone explain me the difference between M1 and opus 90w? they seems pretty similar but the pricing is not
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    M1-ATX = Generic
    Opus = Name Brand
    Nov 2004
    Italy
    only that? :P
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Fusion-One
    M1-ATX = Generic
    Opus = Name Brand
    LMAO, where did you come up with that?
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Frankino
    Your question is kind of off-topic for this thread but here it goes.
    Check the specs/data sheets for both. The primary difference between the two (other than price) is how the 90W is distributed across the ATX supply rails. The M1-ATX has has a configurable startup-shutdown controller and flashable microcontroller which allows you to insert custom code, if you want. The Opus 90W controller is also configurable (less options and not field flashable) and has been around longer. The Opus name is well respected by many in this community. Search the forums for an opinion on the 90W model.
    You should also be aware that Opus recently released two new lower cost models, The Opus 80W and 120W IIRC. You can find them both in the mp3car store. Search the forums for some information about those options.
    Finaly we can change the timings to some thing use full. Say 15 tell soft off and 16 tell hard off.
    Nov 2004
    Italy
    ok coming back to topic, what is the procedure to upgrade the M1 firmware?
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Aug 2004
    California
    You'll need a PIC programmer to flash the new firmware to the microcontroller.
  1. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  2. master volume doesnīt work
    By free2world8000 in forum RR Bug Tracker
    Last Post: 02-17-2005, 01:08 PM
  3. I cannot get the new version to show up ????
    By tolisn in forum RR Bug Tracker
    Last Post: 02-14-2005, 12:37 PM
  4. Update: 2-12-05.. Flash Support!...
    By guino in forum Road Runner
    Last Post: 02-13-2005, 01:21 PM
  5. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 01:36 PM
