Results 1 to 8 of 8
Thread: extra long molex cables??
    Jun 2004
    The North, Manchester
    Moving the CR ROM from the boot to the dash but leaving the rest in the boot - any ideas where i can get extra long cables from? got the IDE sorted but need to run the power.
    i believe its +12 +5 and ground. can this be taken from the vehicle elec system (would prefer to just extend cable from box though...
    ta nick
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    if its a slim CDrom you only need the 5V (red and the black next to it). I would just go get a couple of metres of cable from maplins and splice into a power line or get some molex pins and connector ready to be made up.
    Mar 2004
    Vancouver, BC, Canada
    Just go buy some wire, and some molex connectors and pins.
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    there are IDE to USB cables for these situations hanzcara Here is an example.
    good luck
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Sep 2003
    Austin, TX
    I wonder how it can bus-power an IDE drive with just that cable...
    Raw Wave
    Jun 2004
    On the beach
    It isn't BUS powered, it has a separate 12v molex power supply and transformer that plugs into the mains.
    Sep 2003
    Austin, TX
    I had some wire and an old Y-adapter lying around, so I hacked up the Y-adapter for the connectors and made a detachable power source using 12v and ground for my screen. It's a 5 minute job. And when I need to take the computer out of the boot/trunk, I just disconnect it from the case and leave all the car wiring intact.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    make it
    http://www.maplin.co.uk/Module.aspx?...=1317&doy=10m5 <<male & female molexes
    plus the wire of your choosing
  1. Extra Extra Extra long IDE cables
    By BiggusLaddus in forum General Hardware Discussion
    Last Post: 05-30-2006, 01:03 AM
  2. How do i accomplish this?
    By Danceheaven in forum Software & Software Development
    Last Post: 07-19-2004, 04:48 PM
  3. Long Hard Drive Cables
    By cpritchett in forum General Hardware Discussion
    Last Post: 06-25-2001, 05:25 PM
  4. din cables
    By jasmar in forum Classified Archive
    Last Post: 02-27-2001, 09:21 PM
  5. How long can cables be?
    By ZyKlon X in forum General Hardware Discussion
    Last Post: 12-08-1999, 03:17 PM
