I think ignition is live when key is in the "on" and "start" positions wheras ACC is live with the key in "acc" and "on" positions.
somehow, i was wondering what's the difference between acc and ignition wire. I have being using acc wire in my setup. The acc get power when my key turn to ACC and cut the power when I crank the engine. what about Igntion wire???
2006 Camry
Compaq Laptop
Holux GPS Iguidance 3.0
7" Xenarc Touch Screen
Carnetix 1900 Power Supplied, Wireless b/g
Well, most people seem to call acc and ignition the same. They mean a circuit, or a connection to the circuit, that has power while the car is running. Usualy, if the circuit has power while the car is running, it will also have power when the car is off, but the key is in the acc positions.Originally Posted by Bobby Digital
Sometimes, however, ignition does mean ignition, such as in a remote car start setup.
Hope that helps
Michael
for our uses they are the same...
the ignition or ACC line is off during cranking...
It is NOT really the same.Originally Posted by RoyN
for MOST cars (not all)
ACC only turn on a the radio and aux/cig circuit. These circuits cut off during cranking. Only hot when the key is in ACC <=> IGN(ON)
IGN turn on EVERYTHING in the car (ECU, CC, Power windows circuit, fuel pump, HVAC blower, .... you name it.) And none of these circuit is cut off during cranking. Only hot when the key is in IGN(ON) <=> START/CRANK
So when hook up the car to our purpose do you want everything in the car to be ON when the engine is off just to listen to music or watching movie? The battery is sure to drain very fast.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Actually the power windows and HVAC circuit are on one of the ACC lines. A lot of todays cars have more than one ACC line to accomodate the additional "accessories". The other thing is most cars have a latched output on the ACC lines where the radio, HVAC, power windows, etc. will stay powered until you open your door.
ATVMS.com
As you can see, while there are specific differences between ACC and ignition, most people think of them interchangeably.
Want to:
