You mean the 4-pin 12volt accessory connector?
If your motherboard requires it, the M1-ATX is probably not the right power supply for you, it provides only 2 amps on the 12V line. Generally boards that require the 12V accessory connector draw a bit more than that...
LinkBack URL
About LinkBacks
