Results 1 to 8 of 8
Thread: Dual Battery Setup - How Many Actually Use it?
    May 2005
    United States
    Question Dual Battery Setup - How Many Actually Use it?
    Hey guys/gals,
    I'm new here to the forums, i've been browsing around for some time, but i thought it was time to join. i have been really impressed with some of the installs here at the site, and i want to do basically the same thing to my 2000 Ranger...
    my question is :
    how many people actually have two vehicle batteries installed in their vehicles, with one solely to power their carputer? i think it would be pretty difficult to install a new battery, but i really dont know anything about that kind of stuff.
    my options for power are:
    1) have a second battery just to power the carputer, with a big inverter.
    or
    2) use the battery i already have with an inverter. of course i would put the carputer on hibernate when i get out, so it wouldnt drain any power, but i want to know the risk of that..
    Thanks.
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Quote Originally Posted by andybrown
    Hey guys/gals,
    my question is :
    or
    Thanks.
    I started out powering my truckputer with an inverter just like you, and just using the stock battery. The only real downfall of that setup is that you have to manually put your computer into shutdown or hiberation mode, and manually flip the switch to turn it on. There isn't any risk with this setup, as the inverter completely cuts the power to the computer, it won't drain the battery.
    There are circuits on the forum that show how you can setup an inverter to automatically turn on and off with the trucks ignition using relays, but you will still have to manually send the computer into hibernation before turning off your truck.
    I love the computer in my ranger, and it's good to see there are a few of us ranger owners on here!
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    from what I've read it is not hard to install a second battery. But my suggestion, from experience, is to stay away from the inverter if you can. I know that there are lots of people here that love their inverter setups but I truly recommend against it. I started with an inverter, mostly because of cost, plus I already had an extra AC ATX PSU lying around the house so it made some sense. Boy was I wrong...the inverter just gave me problems, noise in the sound, messed up the shutdown controller (also because of noise), honestly it was a PITA. If your setup does not require a lot of power I would suggest the Opus PSU, a lot of people seem to be happy with it. If you need some more power I recommend the Keypower 250W dc-dc PSU and a shutdown controller (there are several around, I use zoot-jeff's uSDC), that is what I have and the difference is amazing. Plus, if you go dc-dc it's one less thing to wire and find a place for . Just my 2 cents, it all depends on your needs and how you want to set things up, I just hope this information helps you make a more educated decision
    CHEERS!!
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Just from car audio xp, i know a 2nd battery is easy to install. Buying the correct parts can be a challenge...I suggest Optima yellow tops, and searching the forums for a good isolator. In the long run, if you got the $, buy one and you wont ever have to worry about a dead battery or dimming lights...
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    i have been using a second battery for my audio system for a long time now and i think its the way to go. your car will always start because of the diodes in the isolator that prevent one battery from drawing off the other.
    May 2005
    United States
    sorry i've been away for a while. im going to be using a laptop computer is the only thing. so a power supply is out of the question, isnt it?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Why do you need a second battery if you have a laptop? Just plug it in to the inverter and use the laptop battery as your "tank".
    Want to:
    May 2005
    United States
    yeah, i guess that would work. i looked back and now that i did, i realize what i had done, when i first posted this thread i was going to build a small desktop to put into my truck, but then it turns out i decided my little 12" laptop would do. at first i decided not to use it because of the temps that it sometimes gets to but i bought a cooling pad for it and it seems to be doing alot better..
  1. Dead Cell in New Car Battery
    By chewiee in forum General MP3Car Discussion
    Last Post: 05-21-2008, 06:54 PM
  2. FS on Ebay 12VDC 5.1Ah Ignition Backup Battery
    By TheSpecialist in forum Classified Archive
    Last Post: 03-24-2005, 08:32 PM
  3. Will my setup cause a battery drain?
    By Skipjacks in forum Power Supplies
    Last Post: 12-13-2004, 01:09 PM
  4. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 01:46 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
