Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Does anyone know how to create dual battery setup?
  1. #21
    Mar 2004
    London, UK
    Quote Originally Posted by meddler
    I agree on the fuses. but as for the rest, if it is directed at me...
    No, I believe it's directed at hortimech who said this:
    Quote Originally Posted by hortimech
    The main reason for the split charger is so that you do not set fire to the vehicle.
    if you connect a second battery with a cable that is not large enough to withstand cranking amps and the main battery is not fully charged, the starter motor will try to draw current from the second battery and the thinner wire will overheat and melt. If you need any advice about fitting a split charging system, go and see your local caravan dealer.
    and this:
    Thats more like it, but you only need one fuse holder, unless the second one should have been between the second battery and the distribution panel. I would also take the feed from the startermotor terminal.
    What he doesn't seem to realize is that we are not dealing with caravans (where there is nothing switched on when you're driving because there should be no one in it), but with potentially high current drawing audio equipment etc. which will be in use when you're driving.
    Rob.
  2. #22
    Nov 2004
    Quote Originally Posted by fj-mars
    I am going to do the same and bought this thing:
    http://www.kemo-electronic.de/de/module/m102/index.htm
    But now that I am going through all the posts about "tank" I am not so sure. So my question is will it work (the wires on the m102 are a bit thin)? If so this is a very cheap sollution (10$)
    It works great. I build it this weekend.
  3. #23
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    Why are you using an inverter to run a usb hub? I'm running my usb hud off the 5v rail on my mobo. Of course this only works if your usb hub is 5v and not 7.5v!!
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
  4. #24
    Jan 2006
    Guys,
    Just sorting a dual battery for my setup, could you use to relays instead of diodes? First relay would switch on when the ignition key is switched to first click and the second would disingauge the second battery when starting the engine. this way it would not draw amps from the second (deep cycle) battery. When releasing the key it would go back to the first relay and allow the second battery to draw power.
    BUT would this mean the second (start) relay needs to be high current?
    Cheers
    JG
  5. #25
    Nov 2006
    Quote Originally Posted by fj-mars View Post
    I have recently purchased a m102 and wanted some help installing it. I am a little confused as to what I should be connecting to its INPUT, also
    Should I be removing the main RED cable coming from the alternator to the battery and connect it to the M102, then back to each battery?
  6. #26
    Low Bitrate com2soft's Avatar
    Sep 2006
    Need to prevent the main battery charge the backup battery.
  7. #27
    Apr 2006
    Aus Syd
    hi people just 1 stupid quiestion, can intead of 2 batts have 1 masive bat in the boot, and wire it with long *** fat cable to the frount of the car from the alt and fuse box? is it bad cos its too long?
  8. #28
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Are you asking if you can replace your car's battery with this one big battery?
    Theoretically, yes. The fatter the cable, the better it will work. Wire has resistance that drops the voltage over distance. The thicker the wire, the lower the resistance.
    If you are worried about the complications of a two battery setup, just buy a battery isolator. Google it up and you'll find that this is common in a marine setup. You can just buy the solution.
    Want to:
  9. #29
    Apr 2006
    Aus Syd
    can you buy a optima blue top is it same as getting 2 batters cos they are isolated?
  10. #30
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No, it isn't the same as having two physically isolated batteries. The Blue Tops are connected either in series or parallel. Either way, the cells are not isolated electrically. They are isolated physically.
    Want to:
  1. Will my setup cause a battery drain?
    By Skipjacks in forum Power Supplies
    Last Post: 12-13-2004, 02:09 PM
  2. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 02:46 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. How fast of a computer needed for dual monitor (GPS & DVD) setup
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-23-2004, 04:29 AM
  5. WTT: Dual AMD Server for your Carputer setup
    By DaMaN in forum Classified Archive
    Last Post: 07-23-2003, 12:23 AM
