Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Does anyone know how to create dual battery setup?
    May 2005
    Just like to know does anyone know how to create a dual battery setup and if you have any info could you please post would be very helpfull.
    Low Bitrate M11VNY's Avatar
    Aug 2004
    Leicester & Reading, UK
    Yep!
    Had one in my old car,
    Put the battery in the boot (if thats where its gonna go), Earth the negative of the battery well to the car chasis. You can then run a 4 gauge wire from the positive to the back battery.
    But you will need to put a split charger relay on the link as if kept connected whilst the car is not running the two batterys will discharge each other. The cheapest one I found was at maplins.
    For something like 15. you will need to connect the relay to the ignition, which activate the relay once car is running and charge the back battery. Or you could just have a switch but you run the risk of forgetting it switched on!!
    Its down!!!! Sold the Golf so took it out, it's still alive but not installed.
    Progress [-----------] 0%
    Who the Daddy Iz!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Search on terms "tank circuit". There's tons of info on how to do it.
    Want to:
    May 2005
    A pic is worth a thousand words.
    Low Bitrate GRod's Avatar
    Aug 2003
    San Diego
    I have a dual battery set-up in my truck (one for all my goodies ) and one for running the truck. You can check out my setup at this link http://fordtruckworld.tenmagazines.c...-1-album-21509 and this one http://fordtruckworld.tenmagazines.c...ery.ten?id=288
    I got all my supplies from these guys http://www.wranglernw.com - they have the dual battery trays, solenoids, switches - everything you need - plus they are very helpful and patient with your and your questions. Here's a link to their dual battery application catalog - while for trucks, I'm sure they could help you with your application in any vehicle. http://www.wranglernw.com/flyers/Wra...%20Catalog.pdf
    Good Luck!
    GRod
    Carputer/AV System ~95% complete
    Parts all acquired - testing underway
    Fabrication and integration underway
    More on my Ride
    Apr 2005
    lancashire
    Quote Originally Posted by M11VNY
    The main reason for the split charger is so that you do not set fire to the vehicle.
    if you connect a second battery with a cable that is not large enough to withstand cranking amps and the main battery is not fully charged, the starter motor will try to draw current from the second battery and the thinner wire will overheat and melt. If you need any advice about fitting a split charging system, go and see your local caravan dealer.
    Maximum Bitrate DeltaFX's Avatar
    France
    Or add a big diode between main battery and puter battery on the + line. Alternator will charge both, and when cranking, the diode will prevent sucking juice from the pc battery
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    A schottkey diode prevents this and eliminates the need for a separate charging circuit. The plans are on here, just....(rhymes with lurch)
    Want to:
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    try this... Credit for this circuit goes to my mate Darren Pollard. I'll clean is up and repost when I have time. Basically once the alternator puts out a voltage on the indicate line the 12V contactor is closed hence charging the second battery. This contactor can be manually shut by pressing the push button illuminated switch. Disregard prices, they are in AU$
    Apr 2005
    lancashire
    Meddler's way of charging the second battery is way over the top, you just really need the 30amp relay. If you did connect the second battery with normal starter motor cable, you would not need anything else as this would stand the cranking current.
  1. Will my setup cause a battery drain?
    By Skipjacks in forum Power Supplies
    Last Post: 12-13-2004, 02:09 PM
  2. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 02:46 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. How fast of a computer needed for dual monitor (GPS & DVD) setup
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-23-2004, 04:29 AM
  5. WTT: Dual AMD Server for your Carputer setup
    By DaMaN in forum Classified Archive
    Last Post: 07-23-2003, 12:23 AM
