Results 1 to 10 of 13
Thread: Fittin OPUS 150 inside case.
    Illinois
    1.)Does anyone know of any cases besides a homemade one of course, that will fit an OPUS 150 on the inside.
    2) Is there any way to keep the OPUS on the outside of the case and still power it?
    3) If powering the machine with the OPUS outside of the case, how do you run the 20 pin mobo connector and HD power connector from the OPUS to the inside of the case?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    I can answer 2, a lot of people power the pc with the 150 from outside the case, since cooling is a big issue for this psu some people recommend it. (mine however is in a homemade)
    PC Components:
    My work log
    Super Moderator xBrady's Avatar
    USA
    Any case will fit the Opus if you pull the other PSU out.
    Installed.
    -GPSSecure- - GPS Tracking
    Illinois
    xBrady, can you direct me to any cases where this would work? Would it fit inside the Morex 669 case? http://www.morex.com.tw/669.htm
    Peoples, if powering from the outside, how do you get the 20 pin connector and the hard drive power cable from the OPUS into the case? Would you need to cut holes?
    Jan 2004
    Jersey/NY
    I pass mine through a slot where you'd have a PCI card.
    FLAC -zip-'s Avatar
    Ontario/Canada
    I have a slim line case, used thin foam tape around the PSU hole so that the wires would not scrape against sharpe metal. My Opus and my hard drive are both outside the case. The opus will not fit in my slim mATX case.
    Sound Stage
    Eclipse|MTX|Infinity
    Jul 2004
    Quote Originally Posted by xBrady
    None of the hole match up with the OPUS 150. I just tried. It's a full size atx case.
    Tainted Love Cris's Avatar
    Romania
    I have an Opsu 150W in the Travla C137. It fits perfectly.
    Jul 2004
    Quote Originally Posted by Cris
    Do the holes match up properly in a full size case? Sorry, but I'm actually trying it right now. Is the C137 a full size ATX case?
    Dwaine.
    Romania
    Quote Originally Posted by Dwaine
    Dwaine.
    No, it's a minitix case.
    You have to make a new metal plate for the Opus to fit on, and fit this plate to the holes in the case. Mind you, I'm taking about the PCB version of the Opsu, or the one without the case...
  1. suggestion for a case for OPUS 150w (boxed)....
    By Maskone in forum General Hardware Discussion
    Last Post: 07-29-2005, 12:40 AM
  2. Opus 150 and Athlon XP?
    By philstuf in forum Power Supplies
    Last Post: 04-18-2005, 09:05 AM
  3. Recommendations on the fastest mobo & processor that can be used with opus 150
    By clean customs in forum General Hardware Discussion
    Last Post: 03-03-2005, 10:02 AM
  4. Replies: 23
    Last Post: 12-14-2004, 12:02 PM
  5. OPUS 150 watt now in stock in the official mp3car store!
    By Zip-Lock in forum Power Supplies
    Last Post: 06-24-2004, 07:56 AM
