Results 1 to 3 of 3
Thread: Doing my wiring now, quick question
    Dec 2004
    BE
    Hi, I'm sitting by my car as I type. I have hooked up the +12, the ignition(also to the +12) and the ground of my M1-atx. What are the ouput values that I should be able to read?? Currently I only find the -5V on the output. All the others are not there it seems. Do they only have output when something is connected to them. Input is fine thoug, measured it at a steady 12,48V.
    Background info, I put a 10A fuse by the +12V and if I connected everything it blew. So now I'm doing it step by step to see where I went wrong.
    Did I already blow up my M1-ATX? The onboard fuse of the M1 is fine though.
    Thanks for the quick help, cause I'm going crazy here.
    EDIT: the fuse popping was from the fact that 12V and grnd touched for a moment. didn't keep them away from each other well.
    Dec 2004
    BE
    AAArrgh, it's not getting any better. I read a few other posts that I should first connect the MB-on switch. Could that be the prob??
    EDIT: Mine isn't even working in dumb PSU mode though
    Dec 2004
    BE
    Ok, so now it's working in dumb PSU mode. Of to search previous threads.
    EDIT: I guess I'll need a new pic. Hope to get it soon(Andrei?), but in the meanwhile I'll use it in dumb mode.
  1. Headless Setup - Quick Amp Wiring Question.
    By crosseye in forum Car Audio
    Last Post: 07-13-2004, 03:18 PM
  2. Starvision LCD.....quick question.
    By Seabass in forum General Hardware Discussion
    Last Post: 05-27-2004, 07:38 PM
  3. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
  4. Audio Wiring question....
    By jusatry in forum General Hardware Discussion
    Last Post: 01-02-2004, 03:08 PM
  5. A question (or two) about wiring
    By Thartek in forum Power Supplies
    Last Post: 08-07-2002, 08:34 PM
