Results 1 to 7 of 7
Thread: Do you think inverter is powerfull enough??
    May 2005
    Hi..i jsut gotta 600W inverter with 1500 peak surge....my computer uses a 350W power supply and using a 15 inch LCD that like uses 40 W....do you gusy rekon my inverter will be powerfull enough to power these 2 things??
    thanks
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Sounds like it should be. I think the rule of thumb is to get an inverter that is 30% bigger than your PSU.
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    I would say more like double but it evetually comes down to the quality of the Inverter.
    May 2005
    Zagreb, Croatia
    My 300W inverter powers 300W PSU and Lilliput. No problems as of yet (3 weeks in car and working). If a PSU is rated as 300W, does it always draw 300W? Because I think that the power consumption is exponential to the number of devices in the case. I have one HDD, one DVD ROM, graphic and sound card and memory. Based on online calculators, I have 120W consumption. Does the PSU draw 120 or 300W in my case?
    Apr 2005
    Minnesota
    Quote Originally Posted by TommyZG
    Power out is (ideally) equal to the power in. There will be loss due to inefficiency. But the rating on your power supply is the max wattage. It won't pull too much more than your power coming out.
    Da_Kooz
    Apr 2005
    Minnesota
    Quote Originally Posted by Deep
    thanks
    Sounds plenty big enough. Only issue i could see is if it is a low quality inverter. then it might give you some issues.
    Da_Kooz
    Variable Bitrate Bodgy's Avatar
    Nov 2003
    Briz Vegas, Australia
    I use a 145 watt psu with a 150watt inverter
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 02:20 PM
  2. Setting up a swtich to turn off inverter when computer turns off
    By hd54321 in forum General Hardware Discussion
    Last Post: 11-29-2004, 02:36 PM
  3. Problems with Xantrex inverter...
    By RoyN in forum Power Supplies
    Last Post: 11-16-2004, 06:26 PM
  4. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
