Results 1 to 10 of 10
Thread: Using same gauge wire when running to a switch.
    Illinois
    If Im placing a toggle switch in the middle of the red power wire than runs into the opus. I think that wire is like 8 gauge. Do I need to also use 8 gauge wire to run to the toggle switch?
    Or could I get away with like 10 or 12 guage?
    Sep 2003
    Elgin, IL
    wire need to be the all the same from power source to ground. the weak point in the system must be the fuse, not the wire. otherwise you risk a fire.
    although 10guage should be enough for a computer...what amperage are you running.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    put the switch on the remote line not the main power line
    Illinois
    I had wrong figures. the wire going into OPUS is 14 guage.
    xd, putting it on the remote doesnt work, because when my computer freezes or shuts down for any unknown reason, Ive had a switch on the remote and it doesnt work.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    you should focus on solving freezing issues
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Sep 2003
    Elgin, IL
    it's not a bad idea to put a switch on the power line either. i have a switch on my main power. my PSU even when turned off still draws 250mA. i'd rather have a switch to make sure it draws 0mA.
    Constant Bitrate emdzey01's Avatar
    Jan 2005
    san fernando valley
    well drawing power isn't a bad thing, since it'll keep your computer on standby. besides, the opus would shut off this whole thing before the voltage reaches below 11 volts right? so you'd still be able to start the car...
    Sep 2003
    Elgin, IL
    not talking about keeping on standby. talking about full shutdown. even when shutdown, motherboard still draw power for such things as keyboard wakeup or wake on lan or stuff like that. it's never totally off.
    Dec 2004
    Quote Originally Posted by nappyjim
    dont run a 14 guage go with a 8 or 10 14 is going to be toooooooooo small
    putting a switch on the remote line should work becasue ur going to cut the remote power to the pc causing the opus to shut down after the certin time frame u set it at or u can tap into ur 2 pin switch on ur mobo and extend it to ur dash with a momentary switch
    Apr 2005
    Queens, New York
    Y dont you just get a momentary push button and connet it to the green and white wires of the mobo---->psu.....THat will restart the computer
  1. Remote On/OF Switch for an Inverter
    By PapaPrem in forum Newbie
    Last Post: 03-09-2005, 10:54 AM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. What gauge wire to use?
    By owenjh in forum Power Supplies
    Last Post: 05-09-2004, 10:52 AM
  4. Replies: 11
    Last Post: 03-09-2004, 09:59 AM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 01:13 AM
