Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: OPUS keeps Rebooting my system
  1. #11
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Great, let us know how it goes
    肚子笑痛了
    S60 Install
  2. #12
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by fromplanetbob
    Okay, why the HELL does the OPUS come with a P4 connector if you can't use the thing with a P4 board!!!!!
    That is the fault of you MB not your Opus. You don't always need it.
    Installed.
    -GPSSecure- - GPS Tracking
  3. #13
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Okay, I just bought this
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5775631414
    It's got 22A continous and is adjustable. So it should more than handle the carputer needs. It's also got a built in AMP meter, so I'll know if I'm over powering.
  4. #14
    May 2003
    Miami, FL
    that should be perfect
    肚子笑痛了
    S60 Install
  5. #15
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    I was ready to tell you that it was your ATX power supply as I read down the posts. I had the exact same problem and it drove me nuts. The voltage drop would put the Opus below the voltage it needed to see to stay running so it would shut down to "save your battery" or so it thinks. Glad you found the solution.
    ATVMS.com
  6. #16
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    yeps, was gonna suggest same thing, i experience this issue in my own car when i forget to start the engine and had the thing running for over an hour playing music hehe. battery gets a lil low, opus sends the shutdown signal to save battery...just gotta drive around the block really quick and i'm good again hehe.
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
  7. #17
    Jan 2005
    Okay, I got the power supply
    and it's working great!
    I'm really amazed, my set up is not pulling near 150w, it's more like 110-120w peak on startup then about 80w continous.
  1. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-20-2005, 11:46 PM
  2. Opus or Mastero MK-4
    By blackpacu in forum Power Supplies
    Last Post: 08-30-2004, 01:37 PM
  3. OPUS Wiring
    By ikhonlord in forum Power Supplies
    Last Post: 08-24-2004, 07:00 PM
  4. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
  5. Complete System with Touchscreen & Opus - $700
    By notion in forum Classified Archive
    Last Post: 12-09-2002, 11:07 PM
