Results 1 to 3 of 3
Thread: will opus be able to power all of this?
    Constant Bitrate emdzey01's Avatar
    Jan 2005
    san fernando valley
    Question will opus be able to power all of this?
    yes, i've already done and it's inside the limit. but just to be sure, this is what i plan on using :
    OPUS 150w dc-dc
    epia m-10000
    512 ddr sdram
    40gig 2.5" hdd
    usb wifi (linksys)
    usb bluetooth (linksys)
    usb gps (delorme earthmate)
    usb audio (audigy2 nx)
    slim combo drive internal
    usb mouse and keyboard
    any input would be appreciated. thanks!
    oh and btw, i plan on powering my xenarc with my opus. is that possible? yes, i already did a . just want your comments on it. but just to make sure, i'm just going to get a molex connector and extend the wires from the xenarc all the way to the opus in the trunk, right?
    and for amplifier turn-on, i'm going to run a wire from my com port's DTR to my amplifiers. right?
    just checking if i'm doing everything right. it's my first time to use the opus, my previous setup was running an inverter.
    all comments are always appreciated.
    Constant Bitrate Trazer's Avatar
    Jul 2004
    The Netherlands
    Quote Originally Posted by emdzey01
    Yep, connect it to a regulated 12Vdc. I did the same with my Lilliput in combination with a carnetix psu.
    There ain't no need to cry. Time's up. It's time to die....
    Jan 2005
    san fernando valley
    thanks for the input. so i guess i'll be having an automatic carputer system with my setup right?
    since my opus and pc is powered on by ignition, and then the xenarc is powered through the opus and also has auto power-on, and then my amps turn on automatically because of the com port's dtr right?
    cool.....
  1. Power supply questions
    By miztahsparklez in forum Power Supplies
    Last Post: 01-24-2005, 11:13 AM
  2. Help me power my Audigy 2 NX from my Opus 150w
    By imprezive one in forum Power Supplies
    Last Post: 01-15-2005, 12:51 PM
  3. Power new PStwo (SCPH-70000) using Opus?
    By smazfam in forum General Hardware Discussion
    Last Post: 11-03-2004, 08:01 AM
  4. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 07:14 PM
  5. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 01:32 PM
